Factory build sheet
Old Mar 13, 2012 | 09:28 PM
Clay master's Avatar
Clay master
Default Factory build sheet
I recently purchased a 71 ls5 and the owner finally sent me the build sheet as promised , he actually sent me 2. One that matches the car and the other one is from another 71. I don't see a vin number on any of these. Is the other build sheet worth anything?
Old Mar 13, 2012 | 09:35 PM
jesse10886's Avatar
jesse10886
yes keep it!!
Old Mar 13, 2012 | 11:42 PM
Mark_Milner's Avatar
Mark_Milner
No, send it to me to dispose.
Old Mar 14, 2012 | 06:56 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
If your talking about "Tank" stickers.......they do not have the vin # on them........ !
Old Mar 14, 2012 | 08:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 427SIXPACK
...If your talking about "Tank" stickers...they do not have the vin # on them...
There might be a hand written job number which may or may not correlate with the VIN. Subtract 500 from the last three digits of your VIN and see if the result matches the job number.
Old Mar 14, 2012 | 09:09 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Sometimes the vin/consecutive unit number can be found on the build/tank sheet. It is typed on the reverse side threw the copy paper on my 72 build sheet, (lower right corner). I believe there have been the same numbers found on some 71 sheets as well. Post some pictures of your find, someone may have interest in your non matching sheet?
Easy Mike, It looks like you can either add or subtract the 500, at every 1000? If that makes sense?
WB
Last edited by Don Rickles; Mar 14, 2012 at 10:52 AM. Reason: added consecutive unit number
Old Mar 14, 2012 | 09:22 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by War Bonnet
...Easy Mike, It looks like you can either add or subtract the 500, at every 1000? If that makes sense?...
When it works, it goes to 500 then starts again at zero. 500 was selected because there were usually about 500 cars on the line in various stages of assembly on any work day, give or take.
Subtracting 500 works for some model years and does not work for others.
It looks like your consecutive unit number and (maybe) key codes were typed on the backside of your sticker.
Old Mar 14, 2012 | 09:41 AM
Don Rickles
2017 C3 of Year
I never thought to check the key codes! I do have them on the sales order, I'll check. Sorry to have to delete the picture. Don't really want the codes out there..........Thanks Mike!
Old Mar 14, 2012 | 10:15 AM
Easy Mike's Avatar
Easy Mike
Could be key codes. I wasn't quite sure myself.
Old Mar 14, 2012 | 10:49 AM
Don Rickles
2017 C3 of Year
Easy Mike,
You are correct! They are the key codes! I posted this question before with no definitive answer. Now, I know for sure what the numbers are. Greatly appreciated! Very
WB
Old Mar 14, 2012 | 02:11 PM
garage-ghost's Avatar
garage-ghost
Easy Mike,
WB
My 72 has both the key codes and last 6 digits of the serial number stamped, in reverse, on the order copy (build sheet). I don't think that started that until 1972.
Old Mar 14, 2012 | 03:20 PM
Easy Mike's Avatar
Easy Mike
So did Bonnet's. Wonder why they put those entries on the back of the sheet? Tis a puzzle.
Old Mar 14, 2012 | 09:36 PM
Clay master
Thanks for
The info
Old Mar 15, 2012 | 06:13 PM
Alan 71's Avatar
Alan 71
Hi cm,
While it's true the front side of the tank sheet doesn't have a VIN on it, it does have an Order Number.
IF you HAPPEN to have the original window sticker you'll see the Order Number on IT too, AND a VIN stamp!
The less desirable the car, the more likely it will be that it has both, but no one will care!
Regards,
Alan
To Factory build sheet
