power range differences
http://www.summitracing.com/parts/SUM-1103/
http://www.jegs.com/i/JEGS-Performan...18#moreDetails
This camshaft, which I also believe is the exact same camshaft, gives the same specs as Summit does, except the advertised duration is 288/298.
http://www.northernautoparts.com/Pro...ctModelId=2283
What the heck is going on here? How am I supposed to trust any of these numbers? Thanks for any help,
Keep the shiny side up!
Scott
Duration @050 is a much better gauge of how it will run in your motor.
As for the difference in advertised duration, that one isn't well defined either. Some measure lift from 0.004", some from 0.006". Again, a fairly useless spec.
As for the cam itself, I ran one years ago in a 350 SBC. With $100 headers, dual plane intake, 600 CFM Holley and pocket ported factory heads it made 240 rear wheel hp on a mustang dyno through an automatic (probably about 300 flywheel). I was very pleased with the cam, excellent driveability and throttle response.
Scott
