1981 corvette
Old Mar 24, 2012 | 02:55 PM
byteme13's Avatar
byteme13
Cruising
Default 1981 corvette
Ok, so this time I have a question concerning my 81 vette. I thought my alternator was not working but when I take off the neg. battery cable the car contines to run. Touching screwdriver to back of alternator indicates it is magnetized. Charge gage only stays in the middle and when I turn on the lights all gages go to the left. Any help would be wonderful.
Old Mar 24, 2012 | 03:34 PM
SIXFOOTER's Avatar
SIXFOOTER
The alternator may be putting out enough current at idle to keep the engine running. You need a voltmeter to acuritely see whats going on. At idle with the lights and all that on you see the voltage drop to 12v or just below. Bump it up off idle and it should return up above 13v. The alternator may be ok, or you could have a bad diode in the regulator if it doesn't keep up with the load. You can pull the altrnator and have it checked at Autozone for free
Old Mar 24, 2012 | 05:05 PM
byteme13's Avatar
byteme13
Cruising
Thank you so much for your quick response.. I will check this all out.
Old Mar 28, 2012 | 06:04 PM
SIXFOOTER's Avatar
SIXFOOTER
I re=read this post. You do not have a charge gauge, you have a voltmeter. If you have at least 12 volts indicated with the engine up off idle your good to go
Old Mar 28, 2012 | 08:59 PM
byteme13's Avatar
byteme13
Cruising
Well I probably didn't state it correctly.. I meant to say all my gauges go to the left when driving or just in idle state.
To 1981 corvette
