*** 1968 Question ***
Old Mar 25, 2012 | 07:18 PM
bkvette3's Avatar
bkvette3
Default *** 1968 Question ***
Hello guys, Just was looking at the underside of my '68 and noticed that I do not have any (what I think they are called) splash shields. These would protect the backside of the footwell. Did early model '68 have these??? If so, are they a one year only '68 part??? If someone could post a pic of what they look like - that would be great. I think they were made of metal. Thanks in advance.
Old Mar 25, 2012 | 07:48 PM
dbeall1968's Avatar
dbeall1968
Do you mean on the firewall, or behind the wheel?
Old Mar 25, 2012 | 07:59 PM
bkvette3's Avatar
bkvette3
In front of the firewall.
Old Mar 25, 2012 | 08:28 PM
7T1vette's Avatar
7T1vette
The '68 and early '69 cars had the firewall splash shields, but they were made of plastic. Those were changed to metal shields, thereafter. If you want to add those shields...and you aren't going for NCRS awards with your car...I would suggest that you opt for the later metal shields. Obviously, GM thought that metal was a better idea. I can't imagine the plastic ones lasting very long under there.
Also, the '68 & '69 cars has some 'under body' metal panels with insulation batting on their top-side. The panels and instulation sheets are still available, but the whole 'shebang' is pretty pricey. I'm sure they would help with cabin heat from the exhaust system, though.
Old Mar 25, 2012 | 08:34 PM
bkvette3's Avatar
bkvette3
Thanks, Charley. I remember seeing a pair of these in my garage awhile back. I don't remember when or where I got them from or where they are now. Now that I think about it they were probably from my '69 coupe that I used to own. (???) I am out to the garage to see if I can find them. Thanks for the help.
Old Mar 25, 2012 | 08:53 PM
682XLR8's Avatar
682XLR8
I had bought the plastic shields for my 68 during the resto....broke both of them during an engine swap
Old Mar 25, 2012 | 08:56 PM
PRNDL's Avatar
PRNDL
Those triangle things? I had a pair of metal ones on my car (had no idea originals were plastic! not fiberglas? ) I took mine off when I put the headers on.
Old Mar 25, 2012 | 09:20 PM
grantstigers's Avatar
grantstigers
Those triangle things bolt to the frame and are triangle shaped. If you install headers of course the tri angle pieces will be in the way.
Blair is talking about the plastic squarish pieces that are mounted in front of the lower fire wall ie put your feet flat against your inside fire wall and the opposite side is the plastice pieces.
68 69 70 should have the plastic shields and 71 up are metal,
hope this helps.
Grant
Old Mar 25, 2012 | 09:22 PM
grantstigers
Blair
68's had the plastic fire wall shields. You have my email address so email me and I can send you pics of the extras I have.
Grant
Old Mar 25, 2012 | 10:15 PM
bkvette3's Avatar
bkvette3
I found the pair that were "hidden/lost" in my garage. Funny how you can find something when you rip half the garage apart. The shields are metal and I do believe they were taken off my '69 427 coupe. I don't know if they were "correct" for that car. I will post some pics.
Old Mar 25, 2012 | 10:17 PM
bkvette3's Avatar
bkvette3
Originally Posted by grantstigers
Blair
Grant
Hello Grant - Good to hear from you - I hope all is well. I will try to find your e-mail addy - it's here somewhere. Thanks BK.
Old Mar 25, 2012 | 10:38 PM
bkvette3's Avatar
bkvette3
Here are the pics. I am guessing these are not correct for my '68 or even a '69. Thanks for the help guys - much appreciated.
Old Mar 26, 2012 | 12:42 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
My original owner 68 built in FEB 1968 has metal splash shields. The shields bolt to the frame and are unlike what is on my original owner 1970 that has a different configuration spalsh shield that has brackets attached to the fiberglass.
The 68 also came with foil backed insulation that was attached under the seating area and went forward through the opening between the fiberglass footwell and the steel spalsh shield to just below the steering shaft.
Old Mar 26, 2012 | 12:46 AM
70ZZ3 96LT4
hope this helps.
Grant
My 1968 original owner convertible built in FEB 68 and my original owner 1970 Corvette coupe built in JUL 70 do not come from the factory with plastic shields.
Old Mar 26, 2012 | 07:56 AM
bkvette3's Avatar
bkvette3
Thanks 70ZZ 96LT - Now I am really confused. Plastic or metal??? Maybe I should hang on to the metal shields I found in the garage - they just may be correct for my application.
Old Mar 26, 2012 | 11:27 AM
loup68's Avatar
loup68
Army
My 68 coupe made in late March, had metal shields and the wet fiberglass insulation and metal shields did not last long before disintigrating. That wet fiberglass rusted everything underneath!
Old Mar 26, 2012 | 02:11 PM
bkvette3's Avatar
bkvette3
Soooo...... would the metal shields I posted pics of earlier, be considered correct for my early model '68??? I am pretty sure I took them off my '69 coupe before I sold it.
To *** 1968 Question ***
Old Mar 26, 2012 | 05:39 PM
PRNDL's Avatar
PRNDL
hope this helps.
Grant
thanks for the explanation, and bkvette, thanks for the pics. Might go take a look and see what (if anything) is under there.
Old Mar 26, 2012 | 10:17 PM
bkvette3's Avatar
bkvette3
Does the '68 AIM show this part??? - If it does I can't find it.
Old Mar 26, 2012 | 10:43 PM
PRNDL's Avatar
PRNDL
No wonder I didn't know what you were talking about. None on my car. I did slap some sticky insulation on there a few years back.
