NJ emissions
Old Mar 26, 2012 | 09:48 AM
Hi-Ho Silver's Avatar
Hi-Ho Silver
Default NJ emissions
Thinking of putting headers and dual pipes on my 78. How do I handle NJ emissions? Car is not on road so I have time...thanks
Old Mar 26, 2012 | 10:49 AM
zwede's Avatar
zwede
Federal law trumps state law and states you have to retain the factory number and location of catalytic converters. Since the '78 only had one cat you need to stay that way. Headers are legal as long as they have the same smog provisions as factory manifolds. Aftermarket high-flow cats are legal.
It's then up to the state how much of that they enforce. But be aware that even if NJ does not check today, they can change the law and start checking at any time.
Old Mar 26, 2012 | 12:03 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
What kind of tags are you planning on using? There is no inspection if you run Antique tags. If you run regular use plates, you get an emission test once every two years. I have not seen them do a visual on mine, but with a '70, it didn't come with cats. The idea that you can't go to a dual system with modern high-flow cats, a better system BTW, is stupid. I know it is the federal law, but it is a stupid law.
Old Mar 26, 2012 | 01:46 PM
zwede's Avatar
zwede
But there's no IQ test required before becoming a law-maker.
Old Mar 26, 2012 | 02:45 PM
startwith80vette's Avatar
startwith80vette
Very simple, get historic registration and do whatever you want. No inspection and registration is free renewal through the mail every three years.
Old Mar 26, 2012 | 05:31 PM
tomgallucci57's Avatar
tomgallucci57
but you cant drive everyday with historical plates,some cops might pull you over.in ohio,your only suppost to drive to parades,and car shows only.plus they require the front plate.but you could take a chance with historical plates,and hope they dont bug. dont know n.j. laws. or just remove the cats after the inspection
Old Mar 31, 2012 | 11:23 AM
Hi-Ho Silver
Thanks for the info.. I guess I'm going historical.
Old Mar 31, 2012 | 12:29 PM
Lupigiato's Avatar
Lupigiato
Old Mar 31, 2012 | 01:26 PM
Toolman1953's Avatar
Toolman1953
When I got mine inspection is good to 2013 cliped the cat when inspection due again will register with QQ plates.
Old Mar 31, 2012 | 01:48 PM
bigjoepos's Avatar
bigjoepos
To get the QQ's you need to send two pictures.
My new toy (1981) has some mild modifications (see avatar), hood is a bit higher and grounds effects kit.
How strict are they in giving the plates? Would I get rejected for QQ because of these mod?
My 76 would qualify as it is totally stock but it goes through inspection every two years no problem.
To NJ emissions
