Emblems
Old Mar 26, 2012 | 09:18 PM
holden7896's Avatar
holden7896
Default Emblems
Im about to buy some emblems for my 82. I dont see any holes where they would attach with nuts. Do they have adhesive on them?
Old Mar 26, 2012 | 09:21 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Legit emblems should have holes , sounds like someone putty'd over them?
Old Mar 26, 2012 | 09:40 PM
holden7896's Avatar
holden7896
So there should be holes on the bumper where they would go?
Old Mar 26, 2012 | 09:50 PM
oldalaskaman's Avatar
oldalaskaman
some of the aftermarket use double stick tape, 3m works the best.
Old Mar 26, 2012 | 11:30 PM
holden7896's Avatar
holden7896
I'm buying them out of a catalog so hopefully they will be sticky. They're really expensive, does anyone know where to get them cheap?
Old Mar 26, 2012 | 11:43 PM
oldalaskaman
I have bought the cheap ones from ebay, they're always 2nd's , dont buy cheap, there's no substitute for 1st class
Old Mar 27, 2012 | 12:22 AM
7T1vette's Avatar
7T1vette
The later year C3's used 'stick-on' emblems with double-sided tape cut-outs on their backside. I believe that 'new' emblems come with that adhesive stuff already on them. But, you might check with the vendor you are using before you purchase.
Old Mar 27, 2012 | 12:30 AM
holden7896's Avatar
holden7896
How much worse cause I'm on a low budget
Old Mar 27, 2012 | 12:54 AM
gbvette62's Avatar
gbvette62
All original 82 Corvette emblems required holes to install them.
Original urethane rear bumper covers had 3 holes (actually I think they were more like slots) in them, to attach the rear emblem. If the car has had a fiberglass rear bumper installed, there will be no holes in it, unless the installer put them in it.
The rear bumper Corvette emblem, was attached by 3 speed nuts. GM made ones have been discontinued about 6-8 years. The current repro sells for about $50. If you don't want to put holes in your bumper cover, you can remove the studs from the emblem, and install it with double sided trim tape.
82 nose and gas door emblems (except for Collector Edition ones) still come from Chevrolet, which is why the list price is around $100 each. The nose emblem is installed with double sided tape (supplied with the emblem), but it still has 2 short studs on it, to properly position it on the nose. The gas door emblem does not use tape, but instead is attached with two 1/4-20 acorn nuts.
The fender "Cross-Fire" emblems are also installed with double sided tape, and like the nose emblem, they also had studs on the back to position them on the fenders.
Old Mar 27, 2012 | 01:02 AM
holden7896's Avatar
holden7896
I have holes on the gas tank
To Emblems
