Cure for droopy visor?
Old Mar 26, 2012 | 09:49 PM
ENASNI TILLER's Avatar
ENASNI TILLER
Default Cure for droopy visor?
Any cure for this problem? I've been using electrical tape hehe. I can push it up, but after a couple of bumps it's right back down. I know I can't be the only one
Old Mar 26, 2012 | 10:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you have standard non tele visors... sure there is. Pull the visor off the rod, lay a towel on top of the visor and tap to tighten up the reinforcement on the rod.
On your car and with standard visors.... there is a metal frame that goes around the rod and holds tension. Tapping this down a little bit and then driving the rod back in will solve the problem.
Willcox
Old Mar 27, 2012 | 12:02 AM
scottyp99's Avatar
scottyp99
Huh!!! You would think a business like Willcox would try to sell you new ones, but instead, they tell you how to fix the old ones! You just don't see that much anymore. I am going to make a point of buying something from Willcox in the near future just because of this!
Keep the shiny side up!
Scott
Old Mar 27, 2012 | 09:38 AM
BKarol's Avatar
BKarol
There is a reason for the towel. When you start to tap or grip or whatever that visor material is fragile and can easily tear.
Old Mar 28, 2012 | 09:19 PM
0Willcox Corvette
Former Vendor
Scotty.. Thank you... It's the way we were brought up.. Pay it forward.
Old Mar 28, 2012 | 09:39 PM
tonak's Avatar
tonak
I have the telescopics and my driver side is a bit floppy. I thought about replacing the plastic bushing, then I flowed just a tad of thin cyanoacrylate glue in and it has worked well! Kind of Bubba, but you would never know it
Old Mar 28, 2012 | 09:51 PM
0Willcox Corvette
Former Vendor
Naw.. that isn't bubba.. bubby would have stuffed some paper and bondo in there... besides he can't even spell cyanoacrylate... oh crap, for that matter I can't either.
Old Mar 28, 2012 | 10:24 PM
ENASNI TILLER
Seems mine is the telescoping kind. Didn't know till I tried to remove it . Anyway, I just put some plumbers puddy on the bushing. Waiting for it to dry to see if it's going to work. If not I'll be in the market for a new bushing
Thanks for the help guys
Old Mar 28, 2012 | 10:41 PM
Duane4238's Avatar
Duane4238
Gee, all the guys I know who have trouble keeping theirs "VIsors" up have used VIagra.
Duane
To Cure for droopy visor?
