Door Adjar Light
Old Apr 9, 2012 | 07:33 AM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Default Door Adjar Light
Yesterday, the "door adjar" light came on as it should when I closed the door improperly. Only problem is is that tje light stayed on. What might be causing the problem and where do I begin to look?
Old Apr 9, 2012 | 07:48 AM
my 76 ray's Avatar
my 76 ray
There is a pin switch at the rear of the door that grounds out when the door is open. If he door is not keeping that switch in, the light will come on or the switch could be broken. I would start there.
Old Apr 9, 2012 | 08:05 AM
Mooser's Avatar
Mooser
Not sure what year your car is.
If you open the doors and hold the switches in (as explained above) and the light goes out... on my 72 there is a squared rubber bumper on the door jam that the switch hits. The new ones don't stick well or whatever and the passenger side one slips down a bit (especially when it's hot) and the light comes on.
Seems it's not quite in the center since it only drops a tiny bit
Mooser
Old Apr 9, 2012 | 08:10 AM
javaman's Avatar
javaman
Thanks guys. Remiss in not mentioning the year - 69. Is that switch near the lock assembly?
Old Apr 9, 2012 | 08:13 AM
7T1vette's Avatar
7T1vette
You can 'exercise' that switch manually, with the key in 'ON' position and the door open. Judge how far in that switch plunger must go "in" to make the light go out. Then use a little clay or Pla-Doh [to one side of that switch] and close door completely...then re-open to see how thick the clay remains. If the plunger height when the light comes on is about the same as the thickness of the clay, then it's likely that the light will be ON or intermittant when the door is closed.
As mentioned above, several (if not all) years had a little rubber pad stuck to the jamb of the door so the switch plunger would hit it instead of the door/paint. That pad thickness will add to the depth of the plunger and assure that door ajar light is OFF when door is closed.
Note: You do not want to force the plunger completely into the switch body; it should stick out just a bit when the door is closed.
Old Apr 9, 2012 | 08:15 AM
Mooser's Avatar
Mooser
Guess it's the same
The one at the front runs the courtesy lights, the one at the rear (switch on the door jam, rubber on the door) near the latch area) runs the ajar lamp
Mooser
Old Apr 9, 2012 | 08:22 AM
javaman's Avatar
javaman
Originally Posted by Mooser
Guess it's the same
Mooser
Somehow, I thought the front switch had something to do with the circuit but now, the way you guys have explained it, I clearly understand where the switch is and how it works (makes contact). Thanks again!
Old Apr 9, 2012 | 10:43 AM
69 Chevy's Avatar
69 Chevy
BTW, there is an access panel at the inside front of the rear wheelwell to get to the wiring behind those plunger switches.
Old Apr 9, 2012 | 11:00 AM
MakoShark72's Avatar
MakoShark72
Isn't the alarm system tied in to either of those switches?? I know the hood switch, but I thought one of the door switches was involved also..?
Thanks!
Old Apr 9, 2012 | 01:37 PM
javaman's Avatar
javaman
Found the plunger and somehow it got bent. Strraightened it out and working fine now - will probably change them both down the road
Old Apr 9, 2012 | 02:23 PM
BBCorv70's Avatar
BBCorv70
Was this a reproduction plunger switch? I've had bad luck with them, they bend VERY easily. Originals were much more sturdy.
Old Apr 9, 2012 | 03:56 PM
Mooser's Avatar
Mooser
I've also found if you don't open the door all the way to get in/out (ie when the car is in the garage and you only partly open the door) I've caught on that plunger with my pant leg more than once.
Mooser
Old Apr 9, 2012 | 04:06 PM
phclub's Avatar
phclub
New England Events Coordinator
If you switch out those switches be careful that the nut assy behind the fiberglass is secure to the body. I unscrewed my drivers side and heard it drop inside the body. The access panel does not allow much clearance to get in there to retrieve the part. I fabricated a new piece and successfuly replaced the assy/switch.
Old Feb 19, 2016 | 08:16 PM
ruken's Avatar
ruken
How does the hood adjar switch work. The drawing shows one wire and ground. Mine doesn't work, Looks simple but also looks like it need another wire to work. I am replacing all three switches. Both door adjars work fine now but the one for the hood doesn't. any ideas?
ruken
Old Feb 19, 2016 | 08:21 PM
Mooser's Avatar
Mooser
The switch on the hood is for the alarm, not the ajar light.
Unless they changed it in later years....
M
Old Feb 19, 2016 | 08:36 PM
ruken's Avatar
ruken
Thanks for your reply! I was trying to make it operate the door adjar light. I guess I could with one more wire. The car(72) doesn't have an alarm system.
ruken
Old Feb 19, 2016 | 10:32 PM
CanadaGrant's Avatar
CanadaGrant
M
On my 69 the under hood switch controls the alarm and both the foot well and rear compartment lights inside the car. I leave a small zip tie on my hood switch as the hood is open quite a bit...
To Door Adjar Light
Old Feb 20, 2016 | 12:43 AM
65GGvert's Avatar
65GGvert
ruken
My 72 does have the door ajar light lit when the hood is popped up. You don't need another wire. When the hood is down, it opens the switch. When you pop the hood even a little, the switch internally closes (completes the path to ground) and lights the same light as the door switches do. Make sure that switch has a good ground and the 12v wire is a solid connection. You can measure the switch with an ohmeter to make sure it's opening and closing. If it never makes contact, the door ajar light will not come on from the hood being ajar.
Old Feb 20, 2016 | 06:31 AM
OZvette72's Avatar
OZvette72
ruken
Invest in one of these, (cheap as chips, simple Simon). To test it you put one end on a battery terminal and the other on the other terminal and a small light bulb glows in the handle, it also works in reverse. To see if you have power to that wire you connect the alligator clip to an earth (metal bracket preferably least paint on it, move it around a bit to get a better contact) and the pointy end on the exposed wire. (should there not be any exposed wire, you can push a pin through the insulation until contact is made with the wire and then just touch the pin with the pointy end)
The hood ajar switch does the same thing when you open it by creating an earth.
Old Feb 20, 2016 | 06:39 AM
OZvette72's Avatar
OZvette72
..... The car(72) doesn't have an alarm system.
ruken
I thought mine was missing until I spotted it tucked up behind the left rear wheel well with it's dirty contacts, bad earth etc.
