Looking for some different ideas for wire looms. big block, points distributor with stock height valve covers, power brakes, covers have the dip in the cover at the brake booster.
Before I go making something, maybe there's something I'll like already out there.
Did some searching and came up with the usual suspects,
Lets see what you got
Mooser
You can see mine better before the engine was put in the car. These use longer valve cover bolts to hold the looms. Makes a nice clean install for the wires...
I prefer to hide the wires rather than have them crawling over the engine like a Octopus......out of sight out of mind and a cleaner look in my subjective opinion.......and with basically stock parts
How do they work going around the corner near the brake booster?
I was toying with the idea of making something that went basically straight up beside the bolt sort of like that but if I can buy the same thing, no use re-inventing the wheel
Mooser
Mooser
They wrap around tight to the valve cover the same way. I can take a picture for you tonight. I have Hydro boost installed so I have a bit more room
That looks like it should work with the booster.
I'll be putting the new covers on shortly and will see what exactly it looks like for room in there but I think I can sneak them around
Appreciate the pics
Mooser
