37 year old wiring
Old Apr 27, 2012 | 10:17 PM
hicswa's Avatar
hicswa
Default 37 year old wiring
I remember reading some where that the wiring in cars was not meant to last for a long time. This seem to be true now that I started to do a restoration on my 75. The wires are very brittle especially by anything that gets hot which is the whole engine bay. I think it would be wise to replace them for fear of a fire. Has anybody else found their wires to be in kind of shape and what is the path that you took?
Thanks,
Danny
Old Apr 27, 2012 | 11:34 PM
80Baby's Avatar
80Baby
My car is 32 years old and I have no intention of reusing any of the original wiring. Not so much for fear of a fire, but once the car is back together I won't have to worry about broken wires or weak connections after I replace everything with new. My only concern will be - did I hook it all back up to the right places.
Old Apr 28, 2012 | 10:17 AM
Alan 71's Avatar
Alan 71
Hi h,
I feel that the engine harness is the one that has the roughest life of the 4, because of the heat and the gas/oil atmosphere.
I replaced it in my 71, but for the others I just inspected, cleaned, and re-wrapped them.
You may find that you'll be able to reuse the others after looking at them carefully.
Regards,
Alan
Old Apr 28, 2012 | 10:30 AM
rugerm44's Avatar
rugerm44
Most of mine on my 71 looks good Execpt some of it under the hood.Soon to be replaced.Luckily no hackers had been into my dash harness.It's in serviceable condition.
Old Apr 28, 2012 | 10:31 AM
oldsarge's Avatar
oldsarge
Like Alan has said, engine harness will be the worse. Be sure to check all your harnesses carefully for any problems. If the others are OK, it would be fine to reuse. Or go new everywhere and then you know for sure. It would all come down to your budget, but reusing some of the wiring, would be a good place to save a few bucks.
Old Apr 28, 2012 | 10:45 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I found some hack jobs on mine under hood and under dash. For that reason, I am replacing everything (69 resto). The other thing is that I had the entire interior out so I felt it would be an opportune time to replace because of ease of access as well as getting rid of 40+ year old wiring.
Terry
Old Apr 28, 2012 | 07:16 PM
7T1vette's Avatar
7T1vette
If the original harness hasn't been "modified", the insulation isn't cracked/hardened, and/or the joints at connectors aren't frayed or badly corroded, there should be no need to replace a C3 harness. Otherwise, have at it. {Not a job I would want to do, if I didn't have to....}
Old Apr 28, 2012 | 09:57 PM
hicswa's Avatar
hicswa
I just took the starter wires off and boy they are really brittle and dry. I think, in fact I know what the plan is going to be. I don't think it will be all that bad to replace since the body is coming off.
Thank,
Danny
Old Apr 28, 2012 | 11:44 PM
Street Rat's Avatar
Street Rat
I just picked up an '81 about a month ago. The first thing I noticed was the deteriorated rubber bushings under the car. The second thing was the condition of the wiring. Poor at best. I'm not going to do any total restoration any time soon but if this baby burns you will all know why.
Old Apr 29, 2012 | 08:16 AM
7T1vette's Avatar
7T1vette
All C3's (and most other cars, too) that have any miles on them also have hardened/brittle/cracked wires at the starter. That area sees a lot of heat/oil/vibration. In fact, in less than 5 years, that new wiring harness will be in exactly the same condition in that area.
The wires in that area really need to be 'high-heat' capable wires with heat shielding on them. You could make that 'fix' on the wiring you presently have....or you can wait a bit before you make that change on the new harness.
Old Apr 29, 2012 | 01:11 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Just out of curiosity, how much would it cost to replace the wires in the car?
Old Apr 29, 2012 | 03:50 PM
Sonny71's Avatar
Sonny71
Oldtimer
Thank,
Danny
Any of the ones under the hood are not bad to replace. If you have to do the dash harness with the fuse box, find someone small and agile (and under 40).
Old Apr 29, 2012 | 03:55 PM
rogman16's Avatar
rogman16
For my '73, 350, Auto, AC, I can get the 4 main harnesses for around $1K...
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Rogman
Sonny71's Avatar
Sonny71
Oldtimer
Dash harness alone on a '71 run about $400
Old Apr 29, 2012 | 07:27 PM
7T1vette's Avatar
7T1vette
Splicing in new wiring (including fuse-links) in the area of the starter....less than $50....{if you do it right}; $10 if you are "Bubba II".
Old Apr 30, 2012 | 09:53 PM
hicswa's Avatar
hicswa
Thanks for the responses.
Danny
Old May 1, 2012 | 01:35 AM
7T1vette's Avatar
7T1vette
Good luck with it.
Old May 2, 2012 | 09:23 AM
Jedi926's Avatar
Jedi926
I have a 78 and after reading this I gave an inspection of the wires. They are actually in good shape. I have only been able to see in the engine compartment. It is my belief that all the wiring is original too, seeing everything on my car is original. It will be interesting to see the condition of the behind the dash wiring.
What I have noticed about the car is the condition of hoses. Most of my smaller diameter hoses are in fair condition and should receive attention. Again, I would venture to say that these are the original hoses too. I guess not bad for 34 years old. I live in the Northeast so the car experiences wicked cold in the winter and the hot & humid during the summer. Anybody else experience this? (especially in the NE)
To 37 year old wiring
