Continuing Starting Issues!!!!
Old May 3, 2012 | 01:25 PM
75_Stinger's Avatar
75_Stinger
Default Continuing Starting Issues!!!!
I thought that with pulling and cleaning the fuse block my starting problems were solved (for about 3 weeks anyways). I am now having the same damn problem.
Drive somewhere park, then the car won't start. Slap some jumper cables on it and it starts right up. I can usually get two more starts after a jump before the car won't start again. The charge on the battery is good, all the lights and the radio work just fine but nothing happens when you turn the key.
I have been expierimenting over the last few days, I have been letting the car sit and I will go out and try to start it every 6 hours or so. Sometimes it will start, sometimes it will not.
Every time I get the car to start I turn it off and immediatley try to start it again, so far once on Tuesday the car started once, then did not re-start right away.
I have NO IDEA what the dang problem is, any input from anyone else is appreciated.
Old May 3, 2012 | 01:35 PM
Stroh's Avatar
Stroh
Hey Stinger I'm having the same problem with my 75. I think I've tracked it down to the starter/ ignition solanoid or the connection along the drivers side, basically right above the front well. I think the corrosion there is the cause. I'll replace it this weekend.
Same exact problem. Someone must have a solution on here if this replacement doesn't work. Brand new battery, new alternator, starter is good ( I think) if this isn't it I'm stumped.
Someone here suggested it might be a bad ground from the battery to frame. I'll clean that area up to and see.
But what a pain. Turn the key and nothing at all, except the fasten seat belt light and radio. Can't drive it anywhere and shut it down for fear I won't be able to start it back up. So it's just cruise out of the garage and back into the garage.
If you sort this before I do, give a brother a heads up and how to, will ya?
Old May 3, 2012 | 01:39 PM
75_Stinger's Avatar
75_Stinger
It is a pain, I will try to get to it this weekend, but more than likely it will be next weekend.
The thing that I don't get is, its not the battery but if I throw jumper cables (not a jump box, jump box won't work), it starts up in like 10 seconds......
Old May 3, 2012 | 01:41 PM
fanmanbd's Avatar
fanmanbd
Get someone to start the car for you and check if you are getting voltage to the solenoid.
Do you get a click or anything when it doesn't start? Do you lights dim?
Old May 3, 2012 | 01:42 PM
Stroh's Avatar
Stroh
I haven't tried the jump yet.
The frustrating thing is that there are no consistent symptoms. It's like it starts when it feels like it. That won't do.
I'll be sure to let you know whatever I can figure.
MelWff's Avatar
MelWff
Check the ground connection to the frame under the battery box. Check the positive connection at the starter.
Old May 3, 2012 | 01:54 PM
Stroh's Avatar
Stroh
Thanks Mel and Fanman,
No dimming on my end. Turn the key and no turn, nothing. I do have strong fasten seat belt light and power to radio, but nothing else. It's just weird. I'm going to get under her this weeknend and check the battery ground. BUt I'm fairly confident it's that starter-igition relay. Kind of a pain to get at too.
Thanks though for the direction for Stinger and me.
Old May 3, 2012 | 02:59 PM
briankeery's Avatar
briankeery
Sounds like some kind of grounding issue....especially if the car starts off a boost.
Old May 3, 2012 | 04:09 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
Stinger-check all connectiosn grounds, I am betting on a bad selenoid in your car.
Stroh-I would bet on plug at ignition or relay - had same thing happen in my 67, was a faulty ignition/key assembly swapped and then it was fine
Old May 3, 2012 | 04:22 PM
billcarson's Avatar
billcarson
don't forget about the, hard to get at, ground that goes from the front frame to behind the starter rear brace.
Old May 3, 2012 | 05:55 PM
boeing46's Avatar
boeing46
My 67 Chevelle had the same problem. When the starter got hot it wouldn't crank. Try another starter and solenoid and check that all connections are clean. New wires may help. If the starter is close to the engine you might try to install a metal shield. Have the starter checked to see if it is faulty. The shield worked for my Chevelle. It also wouldn't run in the rain, another shield to keep water out of the distributor. Good luck, you'll get it because it is a simple circuit. Never assume a new starter is a good starter.
Old May 3, 2012 | 07:15 PM
Spacecoast's Avatar
Spacecoast
Had the same issue on my 72 vette. Got tired of messing with cleaning grounds, etc. so I just put in a new high torque "mini" starter and haven't had an issue. The OEM starter was huge and now I have a few extra inches from the engine so the new starter stays much cooler.
Good Luck
Old May 3, 2012 | 07:36 PM
Ironcross's Avatar
Ironcross
clean the ground from the battery to the frame benind the seat......or this will continue to happen
Old May 3, 2012 | 08:57 PM
Blue73Shark's Avatar
Blue73Shark
Had the same problem on my 73. Cleaned all grounds, rebuilt starter with heavy duty solenoid, and correctly attached the R and S wires (they were reversed). Solved the problem.
Old May 3, 2012 | 10:08 PM
oldalaskaman's Avatar
oldalaskaman
!. loose connection
2. install a 'ford' starter relay, a few chevys actually came from the factory with them installed . I actually know the GM part number for the ford relay. hope this helps, but pretty sure you're arcing off a connection ....somewhere
Old May 4, 2012 | 08:06 AM
Stroh's Avatar
Stroh
Thanks fellas. Electrical gliches are a pain, a time consuming pain... But I'm on it. I'll start with cleaning grounds and connections. If a new starter is the issue then so be it. One step at a time.
And thanks Bill for the pic for that hard to reach ground. We'll sort it out.
Old May 4, 2012 | 08:39 AM
mikecamp's Avatar
mikecamp
St. Jude Donor '12
I had the same problem on my 81 and it turned out to be a corroded ground connection on the ground cable from the battery to the frame.
To Continuing Starting Issues!!!!
Old May 4, 2012 | 09:32 AM
blckslvr79's Avatar
blckslvr79
You said your battery is charged, but did you have it tested?
A bad cell could cause the same issue you are having.
How old is the battery? If your car is not driven regularly this can play havoc on a battery.
I was having the same issue. Sometimes it would start, somtimes it wouldn't. No ryme or reason. Hot or cold did not matter. Battery tested ok, but was 6 years old. I replaced the battery and no more issues.
Old May 4, 2012 | 10:38 AM
gungatim's Avatar
gungatim
Check your battery voltage, should be 12.6v or so.
then check voltage at the starter pos. cable and ground. should be same.
I agree probably grounds not good, or bad solenoid. Solenoids go bad much faster when you have a failing battery or don't have full power to the starter. the mechanical connection in the solenoid can arc and burn making problem worse. easy to fix, pull starter, pull solenoid, disconnect end of solenoid, flip the copper disc upside down and re-assemble. will be like new...
Old May 12, 2012 | 08:33 PM
75_Stinger's Avatar
75_Stinger
Well I am having the same problem, worked on the car today (installed RAAMat in the rear). The car sat all week and started right up on the first crank, I drove it a little bit then I parked it to get to work and it wouldn't start up again.
A buddy was helping me out so four hours and a 12 pack later we finished the RAAMat install, so the doors were open and the interior lights were on the whole time so the battery is definatley no the problem. I tried to start the car a few times just to see what the deal was while we were working, it did start once about 2 hours after it was parked, I ran it for about 5 min and shut it off again.
When we finished putting the car back together it wouldn't start again, we tested the started and there was juice going to the starter but it wouldn't turn over. I slapped some jumper cables on it and it started right up.
Since I live in an apartment I don't have jacks and everything to check the ground, but the ground and the solenoid are my next two things to check tomorrow.
Anyone have any tips?
