Premium Gas?
Old May 11, 2012 | 10:35 AM
briankeery's Avatar
briankeery
Petro Canada Premium since the day I bought her. She may sit for 2 weeks between usage, and I only run about 5000km a summer. I'll justify the added expense in that it gives me peace of mind......and I've given up nearly all of my other "costly" vices.
Old May 11, 2012 | 11:16 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by kjb13
From what I've read, ethanol gas absorbs moisture, giving you watered down gas and poor performance. If this is not a fact, I hope someone clears this up for me, since I drive a little bit to get this gas and it costs more.
And I've read that the sky is falling.
We've had E10 gas here for at least 20 years, other parts of Canada and the US have had it for 30. My toys all sit for six months a year over the winter with E10 in the tanks and NO stabilizer. No problems at all. None.
Old May 11, 2012 | 12:01 PM
7T1vette's Avatar
7T1vette
If you NEED premium fuel...because of higher compression ratio in your engine...you should use it. If you have a low compression engine, you don't need it and you are throwing money away when you buy it. If your low-comp engine doesn't run well on 87 octane fuel...tune the engine.
P.S. Using premium fuel will not 'clean' your engine any better than regular fuel. If you think you need to clean up the carb and/or valves, add some "Fuel Injector/Carb Treatment" stuff to a tank of gas or run some SeaFoam through it.
Old May 11, 2012 | 12:24 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
You can't buy ethanol-free gas anywhere within 100 miles of Chicago. Thanks EPA! Love those "custom blends!" I always run premium in my ZZ4 mostly because you can't hear the engine knock over the side pipes!
Old May 11, 2012 | 03:42 PM
Spocc's Avatar
Spocc
been using mid-range fuel for over 5 years - a little over 30,000 miles
fires fast & runs strong
if i think i have moisture in the tank, a little methol hydrate clears that up quick
Old May 11, 2012 | 05:17 PM
73Corvette's Avatar
73Corvette
Premium is the "drip" gas we ran in my flat head V8 back in high school...
Old May 11, 2012 | 05:27 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by xCCTer
93.
Remember SUNOCO 260 and 280 back in the 70s?
Now THAT was Premium fuel.
Although it was brilliant marketing, I always wondered why Sunoco developed fuels that no production car ever actually needed. Or maybe I just answered my own question.
Old May 11, 2012 | 05:42 PM
Paul L's Avatar
Paul L
My 1974 L-48 runs fine on 89.
Old May 11, 2012 | 05:53 PM
7T1vette's Avatar
7T1vette
EVERY L-48 will run fine on regular....
Old May 11, 2012 | 06:37 PM
loup68's Avatar
loup68
Army
A lot of the 60's high performance cars had 11 or 11 1/4 compression ratio and needed SUNOCO 260 gas.
Power Hawk's Avatar
Power Hawk
Premium only for my Corvette. I consider it a high performance machine and it certainly deserves high test fuel. Although it might not make a difference, it makes me feel better.
Old May 11, 2012 | 06:41 PM
kdf1986's Avatar
kdf1986
I only use premium in all my cars and bikes. I think it is a psychological reason left over from seeing my dad do this in the 60s and 70s.
I use it in my Jeep Cherokee and my wifes Altima also.
kdf
Old May 11, 2012 | 06:49 PM
  #33
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
kdf
I understand where your coming from. Its definitely psychological, and designed to be. The very word "premium" suggests its better than "regular" or "mid Grade". When in fact its basically the same gas with additives that raise its ignition temperature. It doesn't burn any cleaner or create any more power, add to efficiency or even smell better. It just costs more for no benefit at all when run in a car designed to burn 87.
When was the last time your heard someone say or a commercial claim that they got 200,000 miles out of an engine because they ran premium gas instead of the manufacturers specified regular grade?
You might as well fill your tank with regular and take the $10-30 you saved and fling it a buck at a time out the window while you drive around. At least that way you get to have a little fun.
Old May 11, 2012 | 07:55 PM
  #34
Mike Ward's Avatar
Mike Ward
Those engines actually 'needed' and ran at 100% potential on Sunoco 240 which was rated at GM specified 100 RON* octane.
Sunoco 260 was 102ish.
*Edit- Gas today is rated by Anti Knock Index, or AKI. 100 RON is about 94 AKI. I don't know of many Corvettes that need even that- unless the owners like boasting about how much octane they can afford to buy.
Old May 11, 2012 | 08:55 PM
  #35
buckstom's Avatar
buckstom
Default I buy leaded 110 octane
I buy leaded gasoline and it says it's 110 octane. sure burns clean. I only drive about 200 miles a year on my 72. I never have a gasoline problem but now brakes are another thing.
Old May 11, 2012 | 09:12 PM
  #36
FINWOLF's Avatar
FINWOLF
93 octane a can of lead additive
Old May 11, 2012 | 09:20 PM
  #37
terry82's Avatar
terry82
i remember filling up with ethyl.do you remember white gas.
To Premium Gas?
Old May 11, 2012 | 10:09 PM
  #38
vairxpert's Avatar
vairxpert
Octane threads happen in every forum. My favorite is for my Hayabusa motorcycle. 1.3 liter inline 4 producing 175 HP stock. Manual calls for 87 octane.
There are guys that insist on "treating my baby" to 93 octane.
Several decided to play mythbusters and found 87 consistently ran FASTER 1/4 mile times than 93. They then ran dyno tests showing the 87 producing slightly more power than 93.
Even with all that info, you still get the guys that want to treat their baby.
Usually it's also the same guys who don't know how to change a set of brake pads yet are the first to get into a long-winded oil debate.
Old May 12, 2012 | 08:13 AM
  #39
rwaitespiff's Avatar
rwaitespiff
It is true that ethanol will absorb atmospheric moisture over time. However, this is also true of most, if not all organic (chemical designation, not farming) solvents - including gasoline. I don't know if the addition of ethanol into gasoline accelerates this process, but it is worth pointing out that "dry gas" additives pre-date the recent surge of ethanol "enhanced" gasolines.
In a twist of irony, many of the dry gas additives contain methyl hydrate - which is another name for methanol. In essence, the additives one can add to gas to stave off moisture is almost identical to the ethanol already in the gas that we blame for attracting that moisture in the first place.
That said, I run regular unleaded without ethanol. ;^)
Old May 12, 2012 | 10:34 AM
  #40
noonie's Avatar
noonie
It's also recommended that if you use e10, that you not use any alcohol based additives.
If you chose to use an additive, there are many out that don't contain any alcohol.
