Premium Gas?
Old May 12, 2012 | 10:41 AM
  #41
Clams Canino's Avatar
Clams Canino
Originally Posted by kjb13
The tank I'm running now is non-ethanol, 89 octane. I don't know that the octane makes much difference, but the non-ethanol does.
THIS
-W
Old May 12, 2012 | 12:02 PM
  #42
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Originally Posted by Mike Ward
Although it was brilliant marketing, I always wondered why Sunoco developed fuels that no production car ever actually needed. Or maybe I just answered my own question.
Mike,
My first REAL job was at a Sunoco station in '76.
The lowest grade and highest grade fuels were actually mixed by valves in the pump to formulate the mid grades. There were like 6 choices?
Mark
Old May 12, 2012 | 12:20 PM
  #43
Mike Ward's Avatar
Mike Ward
Originally Posted by xCCTer
Mike,
Mark
Yes, it's no different today. Mid grade (89 octane) is a mixture of 87 and 91 done inside the pump.
Old May 12, 2012 | 04:56 PM
  #44
694speed350's Avatar
694speed350
depends on cr. I burn 93 in my 69 with 10.25/1 cr.
Old May 12, 2012 | 06:08 PM
  #45
81pilot's Avatar
81pilot
Higher octant does ZERO to "clean" anything ever. If you run too high of octane just because, it will carbon up, too low and it will predetonate and run lean. Most stock lower compression C3s should run just fine on 87. If you are forced to use high octane be sure to run Seafoam or its equivelant periodically to keep carbon buildup down. Ocatne is the number that tells you at what point under pressure the fuel will spontaneouly ignite. The higher the compression the higher the octane to keep predetonation away. Timing plays a part as well in the equation. I run 87 no Ethanol fuel.
Old May 12, 2012 | 06:54 PM
  #46
7T1vette's Avatar
7T1vette
I'm interested in knowing what "burning clean" means? Is the alternative to that [meaning, using lower octane fuel] "burning dirty"? And, if so, what gets 'dirty'?
P.S. My L-48 engine has 209K miles on it. As far as I know, it has never seen anything but "regular" fuel; the owner's manual recommends 'regular unleaded fuel', anyway. When I pulled the heads for a [lightly] blown head gasket 2 years ago, the pistons were marked for .040"-over and there was almost no ridge at the top of the cylinder walls. I use the GM recommended plugs and they show just a light-tan color when I check them. So, why do I 'need' premium gas?
Old May 12, 2012 | 07:10 PM
  #47
Mike Ward's Avatar
Mike Ward
Congratulations, that's the most compacted and concentrated version of 'gasoline myths' I've ever seen.
Old May 12, 2012 | 07:13 PM
  #48
pleasants9's Avatar
pleasants9
now tell me this why is it more expensive to put non-ethanol gas in my car? because the gas station can get away with it basically?
just in case you wanna find your own ethanol free gas http://pure-gas.org/index.jsp?stateprov=FL
Old May 12, 2012 | 07:55 PM
  #49
loup68's Avatar
loup68
Army
XCCTER, I worked at my buddies Sunoco station for 3 1/2 months and he showed me that they had only two tanks of fuel ( one 260 tank and one 180 I believe) and two pumps, one for each tank. That is how the fuel was mixed, by the two pumps speed. No valves were involved. Actually, it was two pumps in each "pump" with the dispensing hose.
Old May 12, 2012 | 08:18 PM
  #50
N82RB's Avatar
N82RB
my 68 owners manual says premium so 93 it is. I had to drain a tank on my airplane a few months ago so i filled the vette up with 100LL it never ran better.
Old May 12, 2012 | 09:24 PM
  #51
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I run regular in all the cars, no problems.
Old May 13, 2012 | 11:39 AM
  #52
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Precisely! Which is why I only run Kosher fuels. (tongue firmly in cheek)
Old May 13, 2012 | 02:40 PM
  #53
KenSny's Avatar
KenSny
75 L82 S/R Torquer heads, Holley 670 S/A, about 9 comp thru true dual exhaust.
I usually run 89, sometimes 93 BUT NEVER ANYTHING WITH ETHANOL because the engine will chug and knock with that crap.
My 2007 & 2012 Chevs don't care, the computer takes care of it, and they are designed to run on the EPAs current brew.
Old May 13, 2012 | 05:22 PM
  #54
pleasants9's Avatar
pleasants9
is everyone averaging about $0.40 more for the non ethanol gas over 10% ethanol?
Old May 13, 2012 | 05:37 PM
  #55
KenSny's Avatar
KenSny
Better than having the engine knock and chug itself apart!
Old engines do NOT like this new stuff.
If you are concerned about $0.40 install a new crate engine built for today's fuels.
Old May 13, 2012 | 06:20 PM
  #56
vairxpert's Avatar
vairxpert
My engines have run just fine on 10% ethanol for over 30 years. My 75 spent its entire life in my area and started getting 10% ethanol in the LATE 70s and never had a single issue with it. Ethanol is not some new phenomenon sweeping the country and killing engines....it's been the only choice in some emission controlled areas for DECADES.
I've also ran my air cooled 66 Corvair for decades off of it as well as my 1962 Olds with its original 394 Ultra High Compression rocket engine. Neither had any issues with knocking or chugging.
Even the rancid smelling oxygenated gas that appeared in my area in the mid 90s has never given me a single issue in anything from my big V8s to my weed-eater engine.
When traveling well out of my area where ethanol free gas is available, the only difference I notice is a slight increase in mileage.
Old May 13, 2012 | 06:46 PM
  #57
pleasants9's Avatar
pleasants9
I'm not saying its too expensive to afford or anything, I was just commenting. All gas is too expensive...lol I'm really hoping the electric car infrastructure or hydrogen engines pull through
To Premium Gas?
Old May 13, 2012 | 07:16 PM
  #58
Mike Ward's Avatar
Mike Ward
Although I can't say I've seen a definite change in mileage- the 3% difference between E10 and pure gas is pretty hard to track reliably.
Old Jun 15, 2012 | 01:16 AM
  #59
C422's Avatar
C422
Default Actually...
And I've read that the sky is falling.
We've had E10 gas here for at least 20 years, other parts of Canada and the US have had it for 30. My toys all sit for six months a year over the winter with E10 in the tanks and NO stabilizer. No problems at all. None.
E85/E10 has been shown to cause pretty terrible things to happen to engines: http://www.businessweek.com/lifestyl...514_058678.htm
http://www.examiner.com/article/etha...-and-emissions
http://www.nytimes.com/2009/05/10/au...ANOL.html?_r=1
The big 3 are all working on engines that run better with ethanol, and they are FINALLY really getting here. But for older cars? There is very little to suggest it's good for them.
Places like Sears are actually not covering damage to the fuel systems of their gas-powered tools due to the number of problems.
The manual suggests 90 for my car, if I recall correctly. Everything here is either 89 or 91, so I run the 91. And yes, I understand that the evolution of fuel over the past 20 years means that an 89 octane is less likely to diesel, etc, but eh. I can afford $100 a year for the peace of mind that there are no subsonic knocks screwing with my timing.
Old Jun 15, 2012 | 05:35 AM
  #60
Vis's Avatar
Vis
Premium we have 98 octane here in Australia, runs the 73 great and the bike
