Shifter Console Question (pic)
Old May 14, 2012 | 08:24 AM
MrJlr's Avatar
MrJlr
Default Shifter Console Question (pic)
I'm restoring my interior in my '74...
What is the best way to fix this.....you can see where the wood in worn thru to the metal below...
Old May 14, 2012 | 10:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can purchase reproduction appliqués but you may not get an exact match for the original. To be honest, yours is in good shape considering its age.
Old May 14, 2012 | 10:38 AM
7T1vette's Avatar
7T1vette
To refurbish that properly, you will have to remove the [stick-on] wood-grained veneer, use a chemical stripper to remove ALL paint, clean and dry well, shoot new coating of semi-flat or satin black paint, then trim off the paint on top of chrome borders and letters with X-acto knife before the paint gets hard. Once cured (2-3 days, minimum), you can install a new veneer piece (they are readily available from Corvette parts vendors) and it will look like new.
Old May 14, 2012 | 10:46 AM
MrJlr's Avatar
MrJlr
Awesome - thanks.....found the part on Willcox...
Won't I scrape off the chrome getting the paint off the edges ?
Old May 14, 2012 | 11:08 AM
7T1vette's Avatar
7T1vette
Nope. Besides, you don't scrape hard. The unhardened paint just peels off easily. I guess I should have used the term 'shave', rather than scrape. You want the paint to be hardened on the surface, but not all the way through. That way, the peelings won't stick to the other paint as they fall off. Somewhere between 10-20 minutes is about enough cure time. Just be careful not to disturb the fresh paint as you handle that plate when doing the trimming. If you can hold it in place well from the bottom side, you should have no trouble. And, if the first attempt doesn't go well, use it as a 'practice' piece, then re-strip it and try again. No big deal.
P.S. Don't wipe the loose paint trimmings....blow them off. And, if they won't come loose, just wait till the paint is fully cured, then brush them off.
Old May 14, 2012 | 11:10 AM
MrJlr's Avatar
MrJlr
awesome....thank you for the tips !
I'd much rather fix up my part than just buy another!
To Shifter Console Question (pic)
