Exhaust liquid
Old May 20, 2012 | 09:20 PM
holden7896's Avatar
holden7896
Default Exhaust liquid
On my 82 I have true dual exhaust and after a couple of minutes of running, there's a lot of liquid beneath the drivers side exhaust pipe. It's strange because it's only coming out of one pipe and it didn't use to do that. It doesn't smell like gas but this concerns me. Does anyone know why it could be doing this? Thanks
Old May 20, 2012 | 09:24 PM
Mark G's Avatar
Mark G
Its primarily water, a byproduct of combustion, especially with ethonol in the gas. The hot exhaust gas cools down as it goes through the cool exhaust pipe and the moisture in the gas condenses. The condensate collects to form water drops, and that's where the water comes from. Not sure why it's coming out of one side only. I don't think 82's had a heat riser because they had header, unless yours has been changed and you have a heat riser. Otherwise, maybe it's dripping at a joint underneath your car or just collecting in your muffler and hasn't dripped out yet.
Old May 20, 2012 | 09:32 PM
holden7896's Avatar
holden7896
Yeah that's why I'm concerned
Old May 20, 2012 | 11:19 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
I was saying to myself "now here we go" with the responses like, you have to drain that stuff every once in a while, or overflow from the radiator etc. Mark hit the nail on the head. Sometimes you'll see it at the exhaust tips too.
Old May 20, 2012 | 11:24 PM
holden7896's Avatar
holden7896
So its normal and there's nothing wrong?
Old May 20, 2012 | 11:39 PM
noonie's Avatar
noonie
Should dry up after you run for a while.
Old May 20, 2012 | 11:40 PM
holden7896's Avatar
holden7896
Ok good. Thanks!
Old May 21, 2012 | 01:21 PM
my 76 ray's Avatar
my 76 ray
Unless you have a lot of smoke coming out the exhaust it's just condensation.
Old May 21, 2012 | 01:37 PM
keithinspace's Avatar
keithinspace
Water.
This is why it is EXTREMELY hurtful to an engine, and a car, to just start it once in a while, let it idle for 10 minutes, then turn it off.
That's what the PO did to my car for over 5 years. As a result, the sidepipes and baffle system is ABSOLUTELY SHOT. Rotten from the inside.
The car needs to be heated up and driven to the point that all of this excess moisture is 100% burned off/out by the ENTIRE exhaust system getting hot enough to do so. Header to exhaust tip.
As to why it's only coming out of one pipe, I have no clue. True dual? No crossover? Dual cats? Dunno. Maybe one cat works better than the other. Seems a smidge odd, but I don't know that I'd be overly concerned about it if everything is running right...
Old May 22, 2012 | 12:18 AM
7T1vette's Avatar
7T1vette
Stick your fingers in that 'liquid' and rub them together to see if it makes your fingers slippery. If so, it may be coolant that is getting into the right-side head. Hope not. But, better check to be sure.
Old May 22, 2012 | 01:13 AM
holden7896's Avatar
holden7896
I'll do that tomorrow night
To Exhaust liquid
