does anyone rebuild shocks?
Old May 26, 2012 | 01:18 AM
9492's Avatar
9492
Default does anyone rebuild shocks?
Does anyone rebuild shocks? My 71's original shocks are worn out. I would prefer to have the originals rebuilt instead of replacing them. Thanks
Old May 26, 2012 | 08:21 AM
7T1vette's Avatar
7T1vette
Why? Just paint the new Bilstein Heavy-Duty shocks gray....
Old May 26, 2012 | 11:33 AM
9492's Avatar
9492
I had thought about that, but the original shocks are properly date coded.
Old May 26, 2012 | 07:46 PM
7T1vette's Avatar
7T1vette
Ooooooo... Just date code the new ones. Oops! Look out! The "date code police" will be up in arms...
If you are seriously thinking about having your car judged by NCRS or another national group, make contact with those folks and ask what are acceptable ways to change shocks (so that your car is safe) and still score well during judging.
Old May 27, 2012 | 12:01 AM
uxojerry's Avatar
uxojerry
Aldan might be able to rebuild them.
Old May 27, 2012 | 04:57 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Keep the originals. Buy new Delcos and put the originals in their boxes. If you want to have the car judged, put the originals back in. Then after you get your ribbon and piece of paper, put the new shocks back in and go for a nice ride.
Also, your originals could be worth $600 or more to somebody else...who happens to need them for a few more points to get their ribbon and piece of paper.
Old May 27, 2012 | 05:03 AM
7T1vette's Avatar
7T1vette
There's something wrong with a process that requires you to make your car functionally "worse" to obtain an award....
It's like playing "Lowball" Poker.... You can do it; but it's just wrong.
Old May 27, 2012 | 10:12 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
How "original"can you get??
The "original" fluids get used up, the "original" tires wore out, the "original" paint flaked off, etc, etc......
Old May 27, 2012 | 11:01 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Do a search. There was a thread years ago on this subject. I remember that the poster simply drained out the old oil and replaced it. Assuming that the seals are still good, it should work just fine. Apparently the oil inside just breaks down over time.
Old May 27, 2012 | 11:38 AM
uxojerry's Avatar
uxojerry
Try aldaneagle@netzero.com. He is going to rebuild my Aldan coil-over shocks. It shouldnt be much different to do the same with original shocks. The guy seems very helpful and competent. Good Luck!
Old May 27, 2012 | 12:21 PM
BBCorv70's Avatar
BBCorv70
I don't necessarily believe that to be true. Replacement windshields, expansion tanks, or other parts, bought with custom date codes are accepted so long as they appear original. The only part which will not be accepted with phony numbers or date codes is the block.
In this case it may be feasible to renew the original part, adds just a touch more originality to the project than most others. Kind of a one up... If the original tires could be re-manufactured I suspect some would have it done. All part of the original parts game. For some, this is the aspect of the hobby they enjoy.
Old May 27, 2012 | 05:41 PM
7T1vette's Avatar
7T1vette
Why is a 'new' shock that is built to look just like the original unit any different than some other 'new' shock that doesn't look exactly like the original. Neither of them is the original shock, so why do folks get all 'warm and fuzzy' because it LOOKS more like the real thing? (even though it's NOT...)
[This is obviously a rhetorical question...]
To does anyone rebuild shocks?
