Headlight vacuum question
Old May 26, 2012 | 08:25 AM
Flemgunner's Avatar
Flemgunner
Default Headlight vacuum question
After opening the system and letting air in it how long should it take, with engine running to completely get vacuum in the system to operate the headlights? BTW its a 77 vette
Old May 26, 2012 | 08:38 AM
LannyL81's Avatar
LannyL81
About 10 seconds, unless the engine has a high lift, lots of overlap cam....then the headlights may never open.
Old May 26, 2012 | 08:45 AM
Clams Canino's Avatar
Clams Canino
OK - I found that to be funny.
-W (easily amused)
Old May 26, 2012 | 08:53 AM
Mike Ward's Avatar
Mike Ward
When these cars were new, they could be left overnight and still have enough vacuum to open the headlights without starting the engine.
There's the line in the sand.
Old May 26, 2012 | 08:57 AM
Clams Canino
Mike, are you serious here?
I get about a 10 second window after parking to get them down.
And it's been that way since '78. To me that's "normal".
-W
Old May 26, 2012 | 10:26 AM
...Roger...'s Avatar
...Roger...
and that includes the ones with the wiper door.
Old May 28, 2012 | 09:37 AM
JPGearjammer's Avatar
JPGearjammer
Cruising
-W
I had not started my 79 for about 8 years and I was sitting in the drivers seat and for some reason I yanked on the overide switch under the dash and pop! up go the lights.
Old May 28, 2012 | 10:34 AM
...Roger...
Most of the ones I repair will do that.
Old May 28, 2012 | 02:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
And if they don't.. you have a leak in the system somewhere or a defective check valve....
Old May 28, 2012 | 03:42 PM
KenSny's Avatar
KenSny
I have left my car off for a week or more and the lights will still pop up without running the engine.
Old May 28, 2012 | 03:59 PM
Mike Ward's Avatar
Mike Ward
For you guys that cannot raise or lower the lights without the engine running- this means that you have a serious, non-stop vacuum leak that is affecting the A/F ratio to the cylinders near the vacuum port.
Old May 28, 2012 | 04:04 PM
KenSny's Avatar
KenSny
with Mike
This is a not a hard job to replace all the vacuum lines in the headlight system. I have seen the little round filters (up near the cowl) cracked
and leaking air, seen a small pinhole in hoses. Sometimes a devil to track down, easier to replace them all instead of one-by-one.
Old May 28, 2012 | 06:18 PM
lvmyvt76's Avatar
lvmyvt76
Old May 29, 2012 | 01:20 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I vote for electric. Less crap to get in the way, less weight on an already too-heavy car.
Old May 29, 2012 | 03:25 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
What about closing? Mine will not close unless the car is on. I have never tried to open them.
Old May 29, 2012 | 10:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Same. Should open and close once or twice with the engine off.
Old May 29, 2012 | 12:16 PM
7T1vette's Avatar
7T1vette
Except for those vacuum lines that 'see' sunlight or extremely high heat, the vacuum lines themselves are rarely the problem with your vacuum system. The most probable causes for significant vacuum leaks are:
#1 vacuum hose(s) pulled off or left off of a fitting.
#2 seals that are internal to vacuum components (ie, headlight relays, wiper safety switch, etc) are worn out and leaking.
#3 defective components like the wiper door solenoid/valve (behind tach...'68-72 only) or the check valve in the vacuum feed line from the intake manifold.
#4 heater control head vacuum manifold leakage (#1-#3 all can apply here, too).
This all sounds really complicated, until you learn that anything that operates with vacuum is merely an "ON/OFF" switch...it either passes vacuum or it seals vacuum. So checking any vacuum component is as simple as applying vacuum and seeing if it seals or not. Troubleshooting vacuum systems is easier than on electrical system. You just need to buy a little booklet on how these systems work and how to diagnose them. A simple vacuum gauge is a 'must'; they are available at all auto supply stores.
Old May 30, 2012 | 01:46 PM
john roth's Avatar
john roth
I have a leak and EVERYTHING is new except whats under the dash. Goin in again
JR
To Headlight vacuum question
