75 dash braces
Old Jun 14, 2012 | 03:47 PM
oledave60's Avatar
oledave60
Default 75 dash braces
In the 75 AIM on page 115 it shows 3 round braces going from dash area to trans tunnel on pass side and 2 on the drivers side. The AIM shows there to be a bracket with stud spot welded to this hole. I don't have any of these braces and don't see any of the mounting points. Am I missing something? Thanks Dave.
Old Jun 14, 2012 | 03:52 PM
1Fordman's Avatar
1Fordman
I believe only convertibles had the braces. I have a 68 ragtop with the braces . Two friends with a 68 and 69 coupe do not have the braces.
Old Jun 14, 2012 | 04:14 PM
oledave60's Avatar
oledave60
Thanks for the quick reply. I had a hunch that it was for convertibles, but being new to this I wanted to be sure. Dave
Old Jun 14, 2012 | 04:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the AIM; it is my understanding all cars got the braces - coupe and convertible. One of the braces is slightly different for factory AC cars.
I had a 74 coupe and it had the braces.
Fordman: early 68 convertibles did not have the braces. My 68 convertible #41660 has the braces. All 69s were supposed to have gotten them.
Old Jun 14, 2012 | 04:32 PM
oledave60's Avatar
oledave60
I don't have any of the mounting points and yes I do have an AIM.
Old Jun 14, 2012 | 05:01 PM
Easy Mike's Avatar
Easy Mike
If they were installed, the AIM will show them. I think they're in the underbody section, but don't quote me on that.
Old Jun 14, 2012 | 05:29 PM
oledave60's Avatar
oledave60
Well, I think I found the answer. On the bottom of page 115 it shows that these braces are for model 1YZ67 which is a convertible. The coupe is 1YZ37. Thanks for the help. Dave.
Old Jun 14, 2012 | 05:51 PM
Easy Mike's Avatar
Easy Mike
Yep. I am surprised they are convertible only.
Old Jun 14, 2012 | 07:11 PM
Paul L's Avatar
Paul L
I think you will find they are for the convertible.
Old Jun 14, 2012 | 11:03 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Yep, convertibles only. FWIW, if you'll look closely you'll see a 4th brace to the left. Believe they'd likely further strengthen a coupe against cowl shake/flex, tho quite a task to add, but have given up (for now, at least) trying to acquire the parts to make a complete setup.
Old Jun 15, 2012 | 08:50 AM
mysixtynine's Avatar
mysixtynine
Hey Paul... is your car a factory AC car? Wondering if the upper brace is different from 69 due to the AC. I am going to install a VintageAir unit (my car was not factory AC) and they say to discard one of the braces.
I will be fabbing up a new brace so as to keep it in place but was curious if your upper brace is different than mine.
It also seems from your AIM you have a "bolt plate (item5)" in the upper passenger side outer locations whereas the 69 just has holes.
Old Jun 15, 2012 | 09:04 AM
Paul L's Avatar
Paul L
Yes, factory A/C in a convertible.
I am not familiar with the 1969 but here is the upper brace. (It was heater core time.)
Old Jun 15, 2012 | 09:14 AM
mysixtynine
Yeah... the upper brace definitely seems to have more bends in it than mine does.
Thanks Paul.
Old Jun 15, 2012 | 07:33 PM
Paul L's Avatar
Paul L
Thanks Paul.
Yes it does have a couple of bends to clear the ductwork. Sorry I do not have better pics but the heater core job went well and I do not wish to do that disassembly again.
Old Jun 16, 2012 | 08:15 AM
dembo's Avatar
dembo
Dave, your question has been answered, but just wanted to say I like your picture, through the AC hole right up to the nose with nothing in between.
Nick
To 75 dash braces
