Headlight vacuum relay bracket
Old Jul 22, 2012 | 01:33 PM
Maine Vette's Avatar
Maine Vette
Default Headlight vacuum relay bracket
While reinstalling the headlight vacuum system on my 71 this morning I noticed that the bracket that supports the two headlight vacuum relays is missing. I've tried finding a replacement part online, but haven't had much luck. Does anyone have a photo of what the bracket looks like? I'm thinking maybe I can fabricate something if it's just a flat plate with a few holes.
Old Jul 22, 2012 | 02:27 PM
BBCorv70's Avatar
BBCorv70
Part #3966703, shows up on page UPC12 A13 of the 70 assembly manual.
I replaced my headlight relays last year. From what I recall there's not much to it. I tried to take a picture, difficult while installed.
Old Jul 22, 2012 | 03:17 PM
...Roger...'s Avatar
...Roger...
I thought they just screwed to the header bar.
Old Jul 22, 2012 | 03:28 PM
Alan 71's Avatar
Alan 71
Hi MV,
When you look at the AIM sheet BBC suggested NOTICE that the plate has a 'crease' in it so part of the plate is held away from the hood surround so the mounting screws for the relays don't contact the fiberglass.
3 screws mount the plate to the headlight support bar; a template will show you where they need to be on your homemade plate.
Good Luck!
Regards,
Alan
PS: Roger's point.... did the plate appear when there were 2 relays rather than 1?
Old Jul 22, 2012 | 03:38 PM
...Roger...
I had some off a 73 a couple month's ago and I swear they screwed to the header bar,unless there was a plate and I thought it was the bar. Gettin old is hell.
Old Jul 22, 2012 | 06:43 PM
Maine Vette
Thanks for the part number Roger, that should be for a help as I try to find a replacement.
When I bought my car the relays were mounted directly to the header bar. It wasn't until this morning, when I was looking at the routing diagrams in the AIM, that I realized the plate was missing.
I'm certain I could fabricate a replacement pretty easily, but without actual measurements I'm not going to attempt it - too many variables. So now I'm back to trying to find a replacement...
When restoring a Corvette I've learned to always expect the unexpected. It figures I just ordered some parts last night .
Old Jul 22, 2012 | 06:46 PM
Maine Vette
It's pretty odd that the holes in the relays align PERFECTLY with the holes in the header bar - they bolt right up. They fit up so slick that I thought for sure I had the install right - until I looked at the aim.
Old Jul 22, 2012 | 07:02 PM
...Roger...
BBcorv70 came up with the part number.
I just looked at my 73 AIM,I don't have a 71,and it appears to bolt to the header bar.
The AIM calls it the reinforcement.
Old Jul 22, 2012 | 07:31 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
73 mounted to the header bar.... The reinforcement show below is the header bar.
Old Jul 22, 2012 | 07:46 PM
Maine Vette
Very interesting. My 1971 AIM definitely shows a bracket bolted to the bottom of the header bar.
Old Jul 22, 2012 | 07:48 PM
AF_Vette's Avatar
AF_Vette
Tim,
The relays on my 72 are screwed to the header bar directly as well.
Cheers
Vito
Old Jul 22, 2012 | 07:58 PM
Maine Vette
Thanks Vito - good to know. For what it's worth to the discussion, here's a picture of the sheet from my 71 AIM.
I'm guessing that, if it worked without the bracket in 71, I could probably do away with the bracket on my 71. I'm guessing the vacuum hose routing won't be quite as neat though.
Old Jul 22, 2012 | 08:23 PM
0Willcox Corvette
Former Vendor
it will work just fine without out it.. I need to look in to making that part... second call for it in the last month.
Old Jul 22, 2012 | 08:27 PM
AF_Vette's Avatar
AF_Vette
Tim,
Be careful with the daigram. The top red tube is for the headlight washer circuit not vacuum for the headlights.
Cheers
Vito
Old Jul 22, 2012 | 08:53 PM
Dave J's Avatar
Dave J
Here you go. I found this pic in my album from a long time ago. It was taken from a May '70 car before it was cleaned up. Hope it helps.
Old Jul 22, 2012 | 08:56 PM
Maine Vette
Originally Posted by AF_Vette
Tim,
Cheers
Vito
Thanks Vito. I got a little carried away when highlighting the diagram. I chased that one to the end and said "DOH!".
Old Jul 22, 2012 | 08:59 PM
Maine Vette
Thanks Dave - that's a big help. Real good clear picture of where the bracket goes. Definitely looks like it would be easy to make. Maybe someone will be able to chime in with some overall dimensions.
Old Jul 22, 2012 | 09:06 PM
...Roger...
I'll be darned,don't think Ive ever noticed that bracket.
Old Jul 22, 2012 | 09:28 PM
gq82's Avatar
gq82
On my 71 they are also attached directly to the header bar. When I had my car NCRS judged they gigged me 2 points for the missing bracket even though there wasn't a line item for it.
To Headlight vacuum relay bracket
