Voltage puzzlement!
Old Jul 29, 2012 | 04:43 PM
SIXFOOTER's Avatar
SIXFOOTER
Sandpaper is fine to use to clean up sliprings or commutator pieces as long as you clean it up afterward. When I worked in a motor shop we used crocus cloth to clean them up. Sometimes we would get one that was in bad shape and would turn it down on a lathe.
Never known grit from that activity to embed in the copper, its not all that soft.
Old Jul 30, 2012 | 04:39 AM
briaineo's Avatar
briaineo
Hey solved the problem,
Not much required just another volt meter!
The one I was using was faulty, not sure how the digital ones manage give out false readings.
I suppose I have a spare regulator now!
thanks for all the help
Old Jul 30, 2012 | 09:20 AM
JohnRR's Avatar
JohnRR
Originally Posted by centralcalvette
John, what would you recommend to clean up the slip rings ?
I'm sorry to say, but I don't have a good solution for a home repair. The video said to use Scotch-Brite. This would be good as long as it's not coated with abrasive. Otherwise, I would have to take it to a shop that has a lathe and they could take a light cut to true it up.
John
