Door Panel Vapor Barrier
Old Jul 26, 2012 | 09:44 PM
68vetteman's Avatar
68vetteman
Default Door Panel Vapor Barrier
I purchased new door panels recently and they definitely look better than the old set but I'm disappointed with the fit. I think the plastic vapor barrier is part of the problem. The inside of the door panel is some kind of plastic. Do I need a vapor barrier? How much water gets in there. The car never gets wet!!
68 Vetteman
Old Jul 26, 2012 | 10:14 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I made door liners, from the Reflectix material,
mostly to cut down noise and heat, it also makes a perfect moisture barrier.
Old Jul 26, 2012 | 10:38 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
never washed
Old Jul 26, 2012 | 10:49 PM
68vetteman's Avatar
68vetteman
Originally Posted by Scratch
never washed
Only once, T Tops leaked. If I have to I'll spray water from a bottle and wipe.
Old Jul 26, 2012 | 10:57 PM
7T1vette's Avatar
7T1vette
The original door panels are made of a cardboard/fiberboard product that holds its shape very well...as long as it is dry. So, a vapor barrier was needed for use with those door panels. If you have aftermarket panels, they are molded styrene and do not need a vapor barrier. If you still have the original door panels (as I do), you decide how much water it sees and whether you need the vapor barriers or not. (I don't.)
Old Jul 26, 2012 | 11:10 PM
Scratch's Avatar
Scratch
I suppose a no wash is possible
Knew a black Viper owner, that only washed the car once, in about four years of owning it
Old Jul 26, 2012 | 11:14 PM
68vetteman's Avatar
68vetteman
The P/O used silicone sealer to fill the gap between the door and door panel. Not good for fiberboard.
68 Vetteman
Old Jul 26, 2012 | 11:18 PM
68vetteman's Avatar
68vetteman
I only use a detailing spray between waxes. If I do get caught in a storm I wipe it down in the garage.
68 Vetteman
Old Jul 27, 2012 | 07:15 AM
Alan 71's Avatar
Alan 71
Hi 68V,
From what I read, I think your fit problems may be with the panels themselves, not the liners. The original barriers are so thin that they really shouldn't affect fit.
People seem to report troubles with the abs backed panels even when no vapor barrier is used. I think the abs backing is extremely stiff; and sometimes the panel is warped.
Regards,
Alan
Old Jul 27, 2012 | 08:09 AM
redrdstr72's Avatar
redrdstr72
If judging is or may be your thing in the future, you'll want the vapor barriers. NCRS judges look for them. You'll lose points for the repro panel, but you'll lose additional points if the barriers can't be seen. If judging doesn't matter, the plastic substrate makes the vapor barrier a bit unnecessary I think (JMO).
Old Jul 28, 2012 | 03:20 PM
68vetteman's Avatar
68vetteman
Originally Posted by Alan 71
Hi 68V,
Regards,
Alan
I do agree the panels are stiff and the vapor barrier is thin. I'm going to try a screw in the door pull area to help pull it in. Thanks
68 Vetteman
Old Jul 28, 2012 | 06:12 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
I would not use the barrier before I would put a screw where it doesn't belong!!! Think before you do something you will regret!
Old Jul 28, 2012 | 08:06 PM
loup68's Avatar
loup68
Army
68vetteman, 68 corvette door panels have a hidden door pull in the upper portion, and there is a hard, black plastic insert that goes inside of it and it is held in by two screws into the metal door panel. Later production 68's had an added horizontal door pull added underneath the "hidden" one. If you do not have the plastic insert, Corvette America sells them.
To Door Panel Vapor Barrier
