So, my original center console ashtray lid was pretty banged up. I decided I'd give it a thorough sanding (down to bare aluminum) and paint it back up with some Krylon semi-flat.
Turned out AWESOME.
Installed it in the new center console, 12 hours later, gave it a quick test fit, and scraped a 1/4" chunk of the paint off.
So... after some bending of the console arms and filing of the inside edge of the center console where the lid passes through, I've got it PERFECT.
But I have to repaint those scrapes because the bare metal edge is JUUUUST visible...
Second try painting it and had some fat nasty blobs. It's clear my touch-up sanding didn't do the trick.
So I sanded it down to bare metal and built it up again... primer looked great.
Blegh. I'm almost to the point where I'm A-OK with my 'driver' interior. Looks original.
Make something TOO perfect, then you have to KEEP it perfect.
Just like my "distressed" coffee table. It just looks like they had a bunch of kids wail on it with Matchbox cars before it left the factory. So when MY kids wail on it with Matchbox cars, it is impossible to notice.
so are those replacement consoles junk? I need a new one and keep hearing stories of the ashtray doors not fitting right. Do I need to get the replacement ashtray door for it to work properly, or are those junk too?
Hi SR,
I believe there was no primer under those trim parts originally; and, there was a very thin layer of black paint. Maybe your problem was caused by too much paint?
Also, the Krylon #1613 re-coats and blends well, but the #51613 doesn't; it's very different paint.
Which are you using?
Regards,
Alan
If you read the label on most spray cans, it takes several days to fully cure. But, we all want to install that 'good looking piece', just as soon as the paint is 'dry' (but not cured). All spray can paint should be given 2-4 days to cure before reinstallation, so that new scrapes/scratches won't be put back on that piece.
Let the paint cure 24-48 hours before install. This trick has helped me several times.
I've been there too.
Many of aerosol paints will lift if the second coat is not applied within a hour of less. Or you have to wait 48hrs to re-coat. If the paint lifts its best just to use a solvent and wipe the paint off and start over.
Hi SR,
I believe that's the original formula can, but you need to look at the small label on the lower/back side of the can to be sure of the number.
Regards,
Alan
You could have let the paint dry for a month....it's the POS part that the door won't fit into. Waited 9 weeks to get the replacement console, new plastic rivets to mount the door....not even close to being able to close it, at least 1/4" of the lid is blocked by the opening.
Filing was my only option also, when I measured it against the original it was 1/8" shorter, measured front to back. Wasn't cheap to purchase either when I factored in shipping/duty.
My buddy painted this for my '68 in 1978, then I put it on my '73, then another '73... kept it all these years. Actually put it on my current '69, but it was a little too "70s custom" for my taste now, so I keep it on the shelf...
Hi all. FWIW, I have found excellent results in using SEM brand "Trim Black." It flows like, well, butta! Seriously, I've had spotty luck with Krylon but perfect results with Trim Black EVERY time. Spray a LIGHT coat on and watch it flow to perfect coverage. At $10 or so a can, it's a bit more $$$ than Krylon or the other common brands, however, one you use it, you'll never go back -- promise. I buy it at my local auto paint/paint supply house. I used it for my shift console/ash tray door, my fiberglass interior qtr trim panels, my drip rail blackout at the rear of the hood surround, the blackout on the front ends of my doors, etc. I keep a can on the shelf...
After reading up and down the internet, I'm thinking of trying this trim black stuff out as well. Every SEM product I've used in the past has kicked ***.
when you get the paint to where you are happy bake it in the oven at 225*
Thinking this might not go over well with my better half It's a great way to cure paint though. Friend of mine has an old oven in his shop just for this purpose.
