Nose pieces
Old Aug 1, 2012 | 08:45 AM
Kyle.Climer's Avatar
Kyle.Climer
3rd Gear
Default Nose pieces
I jusy bought a 1979 corvette. It has a new nose shell fiberglassed on but its only attached by fiberglass. what other parts will i need to properly mount the nose?
Old Aug 1, 2012 | 09:19 AM
SIXFOOTER's Avatar
SIXFOOTER
If it was glassed in right you don't need anything, basically what was done is it was made all into one piece. Post some pics, we will see what you need.
Old Aug 1, 2012 | 10:33 AM
Kyle.Climer
3rd Gear
Pictures coming this evening
Old Aug 1, 2012 | 10:35 AM
Kyle.Climer
3rd Gear
I will also need fenderwells and some brackets. But i will post the pix later on tonite and check back in after u get a chance to look at them
Old Aug 1, 2012 | 10:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Kyle.Climer
...I will also need fenderwells and some brackets...
I suspect you will need the assembly instruction manual (AIM). Order one for your model year. The AIM shows the factory assembly of the entire front clip and the various parts you will need.
To Nose pieces
