Vert Conversions
Old Aug 2, 2012 | 01:24 PM
jet37ski's Avatar
jet37ski
Default Vert Conversions
Been looking around on here a lot and seen a few old threads about converting '76 and younger to a convertible. They all look great, and the price on the few for sales that I've seen is pretty tempting as compared to a factory vert. There was one up for 10k a couple weeks ago on the site and it really got me interested.
But my question is, how do you address the strength issue? Or do you? I understand these probably aren't going to be high performance track cars, so does the reduced strength or increased twist even matter?
Cost and time aside, am I getting myself into trouble if I'm thinking of buying a later model and doing a conversion myself?
Thanks for any input on this one.
Old Aug 2, 2012 | 01:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by jet37ski
...But my question is, how do you address the strength issue?...
There is no strength issue to address. Convertibles and coupes used the same frames. Most of the underbody and major factory panels were the same. For some model years, convertibles got dash braces the coupes did not get.
...Cost and time aside...
You should not ignore either. The conversion will be expensive and time consuming.
...am I getting myself into trouble if I'm thinking of buying a later model and doing a conversion myself?...
Purchase any assembly instruction manual from any year covertibles were available. Purchase an assembly instruction manual for the model year coupe you intend to convert. Compare the work needed for the convertible with the work done for the coupe.
Honest opinion: if you want a convertible, purchase a convertible.
Old Aug 2, 2012 | 01:41 PM
keithinspace's Avatar
keithinspace
I have to agree.
Both coupe and convertible are fairly plentiful if you pick a little different vintage.
And for the same (or less) money than you'd invest in the conversion, you'd have a vehicle with considerably more "value" than the car you'd be left with if you performed the conversion yourself.
Old Aug 2, 2012 | 04:47 PM
jet37ski's Avatar
jet37ski
That is interesting. I thought I read somewhere that they ended up going with the T top style roof on the coupes because of body twist issues.
Good point. Thanks.
To Vert Conversions
