1981 headlight actuator replacement
Old Aug 8, 2012 | 08:10 PM
brucksch's Avatar
brucksch
Default 1981 headlight actuator replacement
Can I easily remove the driver's side headlight actuator on my 81? Is there enough room to remove the actuator without having to remove any other parts such as the hood or the entire light assembly?
Anyone have some simple instructions? I may have to talk my son through it since I recently ruptured a disk and there is no way I can do the work. In fact, I may have to sell this car and my 04
Old Aug 8, 2012 | 08:22 PM
78pace's Avatar
78pace
Check out Willcox Corvettes website. Under the tech section, Ernie has a great write up with pics on how to remove. Or do a search on this site I do believe the write up was in a recent post. I read thru it and it did not seem hard at all.
Old Aug 9, 2012 | 12:58 AM
kdf1986's Avatar
kdf1986
Yes there is enough room to remove the headlight actuator without removing the hood. You have to remove the bottom valance section and work from under the car. While there may be enough room between the headlight assembly and the opening when the hood is up, there is a chance of scratching your paint if not protected well.
The bottom valence is held in place with about 28 bolts. This is the section that diverts air to the radiator. Once this piece is off you can see the entire headlight assembly and it makes it easier to get to.
The actuator is held in place with 4 bolts. There is a clevis pin at the rod end that will need to be removed also.
Make sure you mark the hoses going to the actuator. One in front, and one in back.
kdf
Old Aug 9, 2012 | 08:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by brucksch
...Can I easily remove the driver's side headlight actuator on my 81?...
You can remove it but I would not define the job as "easy". Are you sure the problem is the actuator? Have you tested the relay?
Old Aug 9, 2012 | 10:30 AM
damoroso's Avatar
damoroso
Easy isn't a word I'd use either...not complicated, but not easy.
Old Aug 10, 2012 | 12:32 AM
SciVette's Avatar
SciVette
I just removed one on my '80. I did not remove the hood or lower air dam. In retrospect I probably should have done one or the other- it was a b!$&# to remove. No space to work and too many parts in the way... Just got the replacement delivered today. Here's hoping install goes more smoothly!
Good luck on your repair. May all your bolts be rust-free and your sockets on-hand the correct size.
Old Aug 18, 2012 | 05:25 PM
brucksch's Avatar
brucksch
Default Headlight actuator replacement
Thanks for pointing me to the Wilcox web site. Nice easy to follow instructions.
It took me 3 hours mostly because 1 nut on the old actuator would not come off. My son drove it to his house and used an impact wrench.
Getting the unit out was not bad. I closed the hood, pushed the unit out and let it rest on the lower cross members. Then opened the hood and carefully angled it out.
Headlight mechanism works great again.
To 1981 headlight actuator replacement
