C3 Build Sheet
Old Aug 9, 2012 | 11:13 PM
327vet's Avatar
327vet
3rd Gear
Default C3 Build Sheet
Is it possible to source build sheets for a 1972 Corvette? I was told that the US only started doing this after 1977 or 1978? I have a 1972 Corvette that I was hoping to get more information on.
I'm in Canada and I have a 1968 that was sold in Canada and I was able to source the information on where the vehicle was originally sold and the options it came with.
Thank you to anyone that might be able to help.
327vet
Old Aug 10, 2012 | 02:23 AM
cgc's Avatar
cgc
I am not sure if a build sheet is the same as a Corvette Order Copy but I know they were on the 68's. I found mine on the top of the gas tank.
Old Aug 10, 2012 | 07:29 AM
Alan 71's Avatar
Alan 71
Hi 327v,
For your U.S. 72 car the best hope is the tank sheet that cgc mentioned.
There's no GM build information presently available.
NCRS does have shipping information on many cars that can sometimes lead to a delivering dealer and further information, but not always. Many dealers are no longer in business and those that are often no longer have the records from so many years ago.
Have you searched for the tank sheet on the car?
Regards,
Alan
Old Aug 10, 2012 | 10:20 AM
327vet's Avatar
327vet
3rd Gear
Thanks Alan and CGC. I will try the top of the tank.
Old Aug 10, 2012 | 12:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 327vet
...Is it possible to source build sheets for a 1972 Corvette?...
No.
...I was told that the US only started doing this after 1977 or 1978?...
Incorrrect, but a hint of truth there. GM contracted with the Allied-Vaughn Company to put GM dealer invoices for 1977-81 on microfiche. That information is now available from Allied-Vaughn.
Some divisions of GM retained paper records. Corvette did not.
Old Aug 10, 2012 | 12:22 PM
cgc's Avatar
cgc
Warning !!
The tank sheet was glued to the gas tank at the factory. If you try to just pull it off you will probably just tear it up. Remember it's only paper and it's been there about 40 years. Sometimes you can feel the top of the tank to see if there is one. You may want to drop the gas tank.
Old Aug 10, 2012 | 03:51 PM
Alan 71's Avatar
Alan 71
Hi,
Again I agree with cgc.
Don't be tempted to even touch it IF you can see it.
Once the tank is down you'll be able to make a decision about how to proceed.... if it's there!
Regards,
Alan
Old Aug 10, 2012 | 04:48 PM
327vet's Avatar
327vet
3rd Gear
Thanks for all the info.
Old Aug 11, 2012 | 10:01 AM
Easy Mike's Avatar
Easy Mike
For clarification. Alan's tank sticker is in great shape and other folks have gotten lucky.
Lots of people find this:
Or this:
Good luck.
Old Aug 12, 2012 | 05:10 AM
hunt4cleanair's Avatar
hunt4cleanair
Or this...
buildsheet stuffed in strut bracket
Old Aug 12, 2012 | 05:26 PM
vettebuyer6369's Avatar
vettebuyer6369
Originally Posted by hunt4cleanair
Old Aug 12, 2012 | 06:01 PM
pigag2's Avatar
pigag2
Hi 327, I am from Ontario and own a 69 that was sold new in Quebec. How did you find out where your 68 was originally sold?
pigag2
To C3 Build Sheet
