Detailing questions??
Old Aug 17, 2012 | 10:57 PM
alconk's Avatar
alconk
Default Detailing questions??
I have started to do a through detail in the engine compartment which means taking everything apart, clean, and repaint but some moron had the engine bay sprayed with clear. Now it's yellowing and cracking everywhere. I don't have a budget to replace items so that's why I'm refurbishing but how in the heck can you get that stuff off?? I've tried lacquer thinner, steel wool, and mineral spirits and can't get that stuff off the rubber parts. Also how would I go about repainting the valve covers?? By the way this is on my 82 and those covers are black with silver ribbs but the silver is very dull... Would it last if I used a silver model paint pen on those ribbs?
Old Aug 17, 2012 | 11:20 PM
Shark Racer's Avatar
Shark Racer
For the VC on my 78, I painted the cover black, and then sanded the ribs smooth.
Old Aug 18, 2012 | 10:53 AM
alconk's Avatar
alconk
Do you have a picture?
Old Aug 18, 2012 | 11:20 AM
Shark Racer
Before
During
After
(it would have paid to better prep work and employ some filler for these particular VCs)
Old Aug 18, 2012 | 06:22 PM
alconk's Avatar
alconk
They look great!! What paint did you use??
Old Aug 18, 2012 | 08:02 PM
boeing46's Avatar
boeing46
Before
During
After
Nice job on the valve covers. I need to do the same. I just wish I didn't have to remove them.
Old Aug 19, 2012 | 02:27 AM
Shark Racer
Can't remember exact brand. Parts store semi-gloss 500* paint.
Old Aug 19, 2012 | 08:55 AM
C3 4ME's Avatar
C3 4ME
I too painted mine valve covers Krylon #1613 Semi Flat black, then sanded the ribs to get the silver showing. The 1613 is no longer available on store shelves, but have read that industrial suppliers, such as Grainger still have it. 5 years later, they still look great. No need for high heat paint IMO.
Old Aug 19, 2012 | 11:25 AM
7T1vette's Avatar
7T1vette
It is best to use a chemical stripper to remove any/all paint from the valve covers (or anything else you are painting) before you prime/paint. Otherwise, the edges of the old paint will show through into the new paint.
You could use either semi-flat/satin black paint or semi-gloss black, depending on the look you want to achieve. I think those were originally semi-gloss black. Either way, you want to use a paint that will withstand up to 500F, since it is in the engine compartment. Dupli-color engine enamel or VHT hi-temp paints are made for that purpose.
Old Aug 19, 2012 | 11:52 AM
Shark Racer
Agreed... I used a chemical stripper and got them down to nothing. There was a lot of other... surface abnormality in these covers. :\
Old Aug 20, 2012 | 11:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by alconk
...how would I go about repainting the valve covers?...
Off the car.
Your valve covers are magnesium. The tops of the ribs may not be an exact silver color. They should be bare magnesium with no color top coat.
Try Google > Images. You are likely to turn up any number of 82 underhood color pictures you can use as photo references.
Old Aug 20, 2012 | 12:14 PM
alconk's Avatar
alconk
Off the car.
Excellent then a nice sand job accross the ribbs should do the trick
Old Aug 20, 2012 | 02:40 PM
Easy Mike's Avatar
Easy Mike
...then a nice sand job accross the ribbs should do the trick...
I've done L-82 valve covers and did not use sand paper. Lacquer thinner on a rag over your fingertip will take off tacky paint and won't leave any sand scratches behind.
A light scrape with a single edged razor blade or a hobby knife will also do the trick.
The old 5-ball Krylon semi-flat black is now classified as an "industrial coating". You can get it through industrial coatings outlets. The old formula is not what you can currently get off the shelf at Wally World. Lots of folks say the new formula Krylon semi-flat black has a tad more sheen to it than the older 5-ball.
To Detailing questions??
