primer
Old Aug 21, 2012 | 01:39 PM
tomgaz's Avatar
tomgaz
Default primer
having a problem i am striping the ac bezel down to metal but when i put the primer on it does not dry i have done this three times with the same results what am i doing wrong.
Old Aug 21, 2012 | 02:28 PM
Alan 71's Avatar
Alan 71
Hi tg,
I've had that situation on trim parts in tight corners where I haven't rinsed the paint stripper off carefully enough.
Try scrubbing with a very stiff bristle brush and very hot water.
Good Luck!
Regards,
Alan
Old Aug 21, 2012 | 03:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Might be bad primer.
To primer
