So I just landed a 73 Stingray. Mechanically this thing is in great shape but the paint is crap. A previous owner did a really terrible white paint job on it. Not all is lost.......I see this as an opportunity to customize it a bit. I'm thinking a glossy black with matte black (or satin) racing stripes. Has anyone seen this? Done this?
If anyone is a photoshop guru I suuuuuuuuuuuuure would appreciate if you mocked one up!!
Well, I put a vinyl stripe on my '71 coupe (see avatar). That way, nothing was permanently changed. Several vinyl graphics companies sell over the internet. Or, if you live in/near a large city, there are likely local companies that can do the install, also.
I don't like racing stripes as bling on street-driven Vettes. But it's a somewhat free country so trash up your car however you see fit. But count on me pointing and smirking if we cross paths.
Reason: Moderator statement removed
Thanks for the opinion though...I guess I did ask for people's thoughts.
I have to agree with you on this. Stripes on a Vette don't work well. There's simply too many body contours that are negated when stripes are applied. .... Stripes look good on old Triumphs, MG's, and even M2 Miatas. Heck, throw some on an old E type Jag also. But on a Corvette? Naw.
First let me say it's your car and your money (obviously), so do what YOU like and don't worry about naysayers. Your car, mod to your preference.
My two cents: I'm with spot 99 on this one. Old cameros and cobras, for instance, don't look right to me without racing stripes... But for whatever reason, a vette doesn't seem to look quite so sleek when adorned with stripes. It does seem to take something away from the curves, which to me speaks volumes about the quality of the design.
Never put stripes on a Vette, but have on older muscle cars. Used some satin vynil striping kits, and turned out quite well. Dip them in a bucket of water, with a squirt of dish soap, and squeegie the water out when applying. Usually ran some vynil pin striping around them too. As mentioned, if you don't like them later, with a little heat, pull off quite easily.
Well, if no one else is going to post pics, I will. I was able to talk my way into an entire roll of free vinyl from 3M. So I put these on my 81. I'm sure some people won't like them (see above ) but I could care less, it's my car. And since it's vinyl, I can experiment with different options any time I want.
I like that!
It's your toy, play with it as you like!
Those look good. Me likey. When the OP posed the question, I was thinking stripes running parallel with the car off-center. My bad because I'm a linear thinker.
Also, you've applied the rookie stripes in the correct direction contrary to original. You did well.
Nothing wrong with stripes on a Vette. Nothing wrong with doing them in vinyl IMHO. What I like about vinyl is that you can change the car up anytime you choose without too much hassle.
