Carburetor Originality Question
So would it be better to rebuild the 74 carb that is currently on the car or buy one from a rebuilder that would probably be off of a Buick/Olds/etc., but I might actually find one that has an appropriate date stamp? How would NCRS handle the originality points for the carb numbers, if I chose to have the car judged? Is it all or nothing for matching model/date? Or would less points be deducted if the date stamp matched but model did not?
Also, is there anything functionally different about the California 74 carb as opposed to a non-California model 1968 Q-jet?
I believe the carburetor line in the 68-72 NCRS Mechanical Judging sheet has 38 originality points, and 22 condition points, for the carburetor, heat insulator, and fasteners.
The carburetor is judged like many other parts; on Configuration, Date, Completeness, Installation, and Finish.
So, a carburetor that was spot on except for the date would lose relatively few points since it does well in 4 of the 5 criteria.
You can go to the NCRS home page and view the judging sheets for your car. You should take a few minutes and check it out!
Regards,
Alan
http://customrebuiltcarbs.com/index.shtml
To add what Alan shared:
It than becomes a question for you is how much do you wish to invest to earn say an additional 7-10 points...as you've concluded? Your correct carb would be the GM# 7028219 with broadcast code DG. The DG code indicates that this carb was specified for a Corvette 327/350 engine with manual transmission and we know that only 9,440 Corvettes were built with this configuration.
This makes the most sense to me. It will either take you some 'time' or big money to find a "correct" carb body. (The body has the numbers stamped into it. You can only swap out the body and keep your other components, if you wish. That is what I would do, anyway.)
Keep the car operational and enjoy it while you are looking for the right parts.
Hunt, thanks again for the excellent information you provided and the suggested action, which I believe is sound advice!
Very good question about the term "correct" and point well taken. I am still very much a novice when it comes to Corvettes and NCRS, but trying to learn more.
When I used the term “correct”, the thought was that it is an “OEM similar model replacement” … a newer Rochester Q-jet as opposed to a Holley, Edelbrock, etc., but that it is not a numbers-matching unit. I realize now that perhaps it was not “correct” to use the word “correct”, since the replacement may have differences of which I am not aware that would render it “incorrect”.
Is there a generally accepted definition of the word “correct” with regard to auto parts and NCRS? Is the"correct" use of "correct" typically synonymous with "numbers matching"?
Someone above said the "California carb" would have been tuned lean. How would you even know? It's NOT the correct carb for your engine - and it could be tuned rich, lean, perfect, and who knows what it'll run like on a 327/350. It's a motorhome carburetor.
If you had the original specifications (air bleed sizes, etc) your 1974 carb could be set up to perfectly mirror the original carb - or be set up perfectly.
At any rate - avoid commercial rebuilders at all costs. They really mess stuff up to make a "one-size" carburetor.
Well let me add that your service replacement Rochester Q-jet carb would be a configuration consistent with the original carb configuration therefore it would score full points..or the 20% for configuration. If its rebuilt with correct plated finish...than it would score the full 20%. If all parts are there (completeness)...than you earn the other 20%. These are all points scored on the originality scale.
If for example you did not have it rebuilt with a refresh on the finish...than you would score the 20% for finish assuming its the correct finish now. But than you lose on condition assuming the finish has deteriorated or faded...kind of the way it works.
