68 gill paint scheme
Old Sep 19, 2012 | 09:39 PM
cgc's Avatar
cgc
Default 68 gill paint scheme
I hope I'm using the right terminology for the four slits in the front fenders on a 68. What was the factory paint scheme for these gills? Where they painted the same as the body color or was part painted black?
Thank you
Old Sep 19, 2012 | 10:34 PM
DZRick's Avatar
DZRick
The 3 front gills were open while the one at the rear of the fender was painted to look like it was.
I believe if you do a search you'll find pictures as well as the type of paint to use.
I was planning on doing mine this year but never got around to it.
Old Sep 20, 2012 | 02:05 AM
cgc's Avatar
cgc
Before I posted I searched using "gill" but must have missed the one on painting. Have any idea what the title was?
So the opened ones are all body color and the closed one is color and black?
Old Sep 20, 2012 | 07:20 AM
daustin's Avatar
daustin
On my '68 the gills are all silver, the rear one that isn't cut out for a vent is painted black where the cutout would be to look like a cutout.
Don
Old Sep 20, 2012 | 08:14 AM
Alan 71's Avatar
Alan 71
Hi cgc,
I believe the openings are often/generally referred to as louvers... perhaps that word may have helped your search.
Regards,
Alan
Old Sep 20, 2012 | 08:50 AM
cgc's Avatar
cgc
Don
Excellent answer. Just what I was looking for. Will do
Originally Posted by Alan 71
Hi cgc,
Regards,
Alan
Thanks Alan you are right again.
I did a search using louver and found what I was needing. If I had used "louver" first there would be no need for this post but I wouldn't have received the excellent answer that I received from dustin.
Old Sep 20, 2012 | 09:06 AM
7T1vette's Avatar
7T1vette
The louvers on the 'base' '68/69 Corvettes were painted body color with the "false opening" on the rear louver painted satin black. In '69 (only) there was an option for installing some (silver) metal louver surrounds on those vents.
Old Sep 20, 2012 | 09:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Body color for all eight. Blackout in each fake rear to give the appearance of a working vent.
Old Sep 21, 2012 | 10:38 AM
FlaVert's Avatar
FlaVert
If I am not mistaken you could get the surrounds in 68 as an option, became standard in 69.
Old Sep 21, 2012 | 11:34 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by FlaVert
...If I am not mistaken you could get the surrounds in 68 as an option, became standard in 69...
The louver trim was not available on the 68s, but got added to a lot of them after the 69s came out. The louver trim was an option, not standard, on the '69s. You had to chip in an extra $21.10 to get them.
Old Sep 21, 2012 | 08:07 PM
Ironcross's Avatar
Ironcross
Factory style
the rear gill is black satin or semi gloss paint to appear as functional as the front three.....
Old Sep 21, 2012 | 08:27 PM
vettebuyer6369's Avatar
vettebuyer6369
Mike is right, optional only in '69, but a popular retrofit to add to a '68.
To 68 gill paint scheme
