Rubber or Polyurethane
Old Sep 22, 2012 | 11:30 PM
Stingray-Jer's Avatar
Stingray-Jer
Default Rubber or Polyurethane
Looking at the sets on Willcox. They are having a sale so I thought I would invest in a rebuild set for the front and back, but I don't know too much about the sets.
http://willcoxcorvette.com/advanced_...rt=3a&&page=-1
http://willcoxcorvette.com/advanced_...rds=suspension
http://willcoxcorvette.com/popup_image.php?pID=25852
Any recommendations??
Old Sep 23, 2012 | 08:52 AM
oldalaskaman's Avatar
oldalaskaman
I used poly control arm bushings and rubber for the rest, not a big change in the ride, and not really needed for the street, but I like them, they come black also if you dont want red bushings.
Old Sep 23, 2012 | 08:59 AM
briankeery's Avatar
briankeery
Unless you're autocrossing the car, rubber will do the job nicely.....especially the initial drive with all new components.
Old Sep 23, 2012 | 10:04 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
While we sell poly... The only parts we will install in our shop is Rubber unless we are working on a road race car.
Old Sep 23, 2012 | 10:46 AM
Street Rat's Avatar
Street Rat
My car is simply a street cruiser so I went with rubber on everything. She sure rides well too.
Old Sep 23, 2012 | 10:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock rubber is fine for a driver.
Old Sep 23, 2012 | 11:03 AM
Stingray-Jer
I'm sold on the rubber bushings. The rubber underneath my 68 is in dire need of replacement. Which of these sets yo you recommend
Old Sep 23, 2012 | 12:12 PM
0Willcox Corvette
Former Vendor
The rear kit I'd go with the deluxe.. the front I would base on what you need.
Rear Kit Deluxe... http://willcoxcorvette.com/product_i...ducts_id=25234
Or you can surf other options here: http://willcoxcorvette.com/advanced_...php?cPath=1998
Front Kit Deluxe... USA made! Ball joints are Moog Lowers and Federal Mogul Upper. This is the same kit we install in our shop. The SU01 kit is the most popular one...
SU01A http://willcoxcorvette.com/product_i...ducts_id=25854
The Deluxe kit is here and pictured below: http://willcoxcorvette.com/product_i...ducts_id=25857
Other options (all USA kits have part numbers that start with SU) : http://willcoxcorvette.com/advanced_...ebuild&x=0&y=0
Old Sep 23, 2012 | 02:02 PM
Stingray-Jer
PM sent
Old Sep 23, 2012 | 03:33 PM
80Baby's Avatar
80Baby
Poly all around. After what I saw with the 29 year old rubber bushings that I pulled out, there was never any question that I wasn't going to stay with rubber. It has nothing to do with the ride. In 20-25 years I'll be too old to redo the rubber bushings and mounts and I certainly don't want to give the problem to one of my kids if I pass the car on to them.
Old Sep 23, 2012 | 03:45 PM
chadronvette's Avatar
chadronvette
Veteran: Coast Guard
I am with 80Baby, I went poly all around, inlcuding the body mounts. could not be happier!
Old Sep 23, 2012 | 04:54 PM
oldalaskaman
x3
Old Sep 23, 2012 | 05:08 PM
Stingray-Jer
Is there a difference in the ride. Do you guys have any squeaking that I hear about?
Old Sep 23, 2012 | 05:50 PM
oldalaskaman
you apply a lubricant to them during assembly, and the real carefull folks , install zerks and keep a tube of the lube for future use, makes them not squeek and last longer also.
Old Sep 23, 2012 | 07:04 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Poly isn't the choice material for all-out AX/RR tracking, but will certainly reduce bushing compliance without giving up ride comfort all together. However, poly it isn't best suited to locations where component movement is inherently in more than one plane, such as is the case with rear camber struts and TA's. Poly also requires proper lube upon installation and the occasional re-lube (squeaking poly is an indication of binding poly). And, if you get CA bushings without serrated sleeves they tend to loosen over time, requiring regular inspection/tightening.
That said, poly does have it's place somewhere in the vast gray area between max performance and max comfort. Then again, if the handling improvements (modest, but definitely noticeable) that might be gained by using poly aren't high enough priorities that the above would likely be too much of a bother, just stick with installing fresh rubber bushings. My $.02, free of charge.
Old Sep 23, 2012 | 07:35 PM
Stingray-Jer
Kelly Johnson would be proud!
Old Sep 23, 2012 | 09:45 PM
MN80Vette's Avatar
MN80Vette
I am glad I installed poly.
To Rubber or Polyurethane
Old Sep 24, 2012 | 12:02 PM
indydoug's Avatar
indydoug
How would 29 year old poly bushings compare to 29 year old rubber bushings? Not trying to be a smart alert, I'm sincerely curious how well poly ages.
For the record, I have poly bushings in my '80 also. P.S. - I wish they were quieter.
Old Sep 24, 2012 | 12:05 PM
oldalaskaman
we'll let you know in bout 28 years
Old Sep 24, 2012 | 12:45 PM
oldC3guy's Avatar
oldC3guy
Question for Oldasaskaman: What lube do you use on the poly bushings?
