Engine compartment cleaning
Old Sep 23, 2012 | 06:17 PM
mk8035's Avatar
mk8035
Default Engine compartment cleaning
Taking engine out. Thinking about sand blasting inside. Our any ideas for me want to get that new look? Also on the paints what type for the wheel wheels firewall and frame? Almost forgot headers?
Old Sep 23, 2012 | 06:48 PM
mapman's Avatar
mapman
Unless you are going to take the car completely apart I would not sandblast - you may never get the blast media out of the car.
If you want a new ORIGINAL look, then spend a few bucks on the NCRS judging manual for your car - it will have descriptions of what the various surfaces were like when new.
I would start with the LEAST agressive clean-up i.e. soap and water, if the car has original stickers/markings.
Old Sep 23, 2012 | 07:10 PM
mk8035's Avatar
mk8035
Default Engine
Thanks thats what i will start with.
Old Sep 23, 2012 | 07:51 PM
Jasonb86's Avatar
Jasonb86
Two words - Simple Green. Ok, actually four - pressure washer. Soak everything with simple green and pressure wash. Make sure to cover as much of your car as much you can so as to not get the grime all over your paint. Then steel wool or chemically strip (w/Aircraft Remover) any rough spots.
Old Sep 23, 2012 | 08:26 PM
1976 corvette's Avatar
1976 corvette
Here is what I did. Best of luck.
http://mycorvetterestoration.com/197...gin_bay_p1.php
Old Sep 23, 2012 | 08:41 PM
AirborneSilva's Avatar
AirborneSilva
I just pressured washed mine today, got all the crude and grime off no problem, I used a 3000 PSI pressure washer. I did spray it with engine degrease last night and let it set to today
Old Sep 24, 2012 | 08:33 AM
Alan 71's Avatar
Alan 71
Hi mk,
You asked about paint.... originally the firewall and fender aprons were painted semi-flat black.
Remember, the majority of parts mounted to the firewall and aprons weren't there when the compartment was painted, so they aren't black.
Good Luck!
Regards,
Alan
Old Sep 24, 2012 | 09:00 AM
AirborneSilva
Good Luck!
Regards,
Alan
yeah I was looking at all the stuff that i will have to paint around, not fun!
Old Sep 24, 2012 | 09:33 AM
mk8035's Avatar
mk8035
Default Engine Paint
For like the Headers what type of paint and the firewall. **** that dont Peel and when it gets hot and re rusts.
Old Sep 24, 2012 | 09:38 AM
AirborneSilva
I bought POR 20 for the headers, will see if it peels or not
For the firewall I bought semi gloss engine ceramic engine paint, that should be safe.
Old Sep 24, 2012 | 01:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...For like the Headers what type of paint and the firewall...
You will want high temperature paint for headers: VHT or similar.
For the firewall, skirts, radiator support, underside of hood, etc, high temperatrue paint is not needed. A good quality rattle can semi-flat black will work.
You will spend more time cleaning and degreasing than you will with actual paint apploication.
Remember: Cleanliness is next to Goodieness.
Old Sep 24, 2012 | 01:36 PM
mk8035's Avatar
mk8035
I believe you i am just starting? Question all the old bolts look like crap. What can i clean them with or do i or should i buy new ones?
Old Sep 24, 2012 | 01:54 PM
Easy Mike's Avatar
Easy Mike
...Question all the old bolts look like crap. What can i clean them with or do i or should i buy new ones?...
Clean them up. A bench grinder with a wire wheel works like a charm.
Old Sep 24, 2012 | 01:59 PM
Alan 71's Avatar
Alan 71
Hi mk,
What you do with the bolts depends on what you want the compartment to look like.
You can use a wire brush to clean them and then re-plate them, or paint them, or spray them with clear to stop them from rusting, or buy new plated bolts. The same decisions need to be made for washers, nuts, screws, etc.
This gets pretty involved and is why some people just paint EVERYTHING black.
Regards,
Alan
Old Sep 24, 2012 | 02:03 PM
mk8035's Avatar
mk8035
De rust and black it is.
Old Sep 24, 2012 | 02:08 PM
mk8035's Avatar
mk8035
Taking everything out to refinish. Question should i take the Brake booster and master cylinder out or finish it were it sits?
To Engine compartment cleaning
