engine missing
Old Sep 26, 2012 | 10:20 PM
CaleBoy's Avatar
CaleBoy
1st Gear
Default engine missing
82 vette' 43000 miles. I love it, but it has a bad miss when I put a load on the engine. Idles fine. About 40 MPH, sputters and bacfires and looses power. Not drivable. Have replaced fuel pump, plugs, wires, distributor, filters. 3 different mechanics - no luck. What could it be? Nit run much ....
Old Sep 26, 2012 | 11:31 PM
chadronvette's Avatar
chadronvette
Veteran: Coast Guard
I think I would look at the carburator. My other thought might be that the timing chain has slipped a tooth. I was in a car years ago that happend in and acted just as you describe.
Just a thought.
Old Sep 27, 2012 | 08:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the timing. Is the computer storing error codes?
Old Sep 27, 2012 | 04:39 PM
straitjacket's Avatar
straitjacket
Just a thought.
doesnt the 82 have crossfire injection?
Old Sep 27, 2012 | 04:43 PM
MrJlr's Avatar
MrJlr
From the title, I was gonna suggest you look under the hood!
(Sorry...had to!)
Old Sep 28, 2012 | 12:55 AM
merc49's Avatar
merc49
if its crossfire then it could be anything,gm mechanics had a hard time fixing them in 82.try to find a old gm mechanic at a dealer and see if he could look at it but my guess is hell run away.i had so many problems with mine i finally went to a carb set up but wouldnt recomend it to the weak of heart or short wallet.
To engine missing
