69 side exhaust spacer
Old Sep 26, 2012 | 11:03 PM
Rick Rowland's Avatar
Rick Rowland
Default 69 side exhaust spacer
I understand that 69's originally equipped with factory side exhaust had a spacer underneath the trans mount. How thick was it? Obviously it raised the trans/tilted the engine slightly. Why was it needed? Did it go between the trans and the rubber mount, or between the rubber mount and the crossmember?
Old Sep 27, 2012 | 07:12 AM
Alan 71's Avatar
Alan 71
Hi Rick,
My understanding is that the spacer is used to fill the gap created between the transmission and transmission mount when the center exhaust bracket is removed because it's no longer needed with the side-exhaust.
That being said....I've also read that St.Louis didn't use the spacer; so? It seems that the spacer would make sense.
Regards,
Alan
Old Sep 27, 2012 | 08:13 AM
KevinG's Avatar
KevinG
The spacer that I ordered from one of the vendors was about 3/32" thick sheetmetal.
To 69 side exhaust spacer
