Springs question
My stock springs are in an OK condition, a little scrubbing and painting and will look like new. Still trying to decide whether to put them back in or go with something like a VBP 460 or 550. I will be getting Bilstein Sports or HDs all around. (I hear better things about the HDs)
Will the ride height change noticeably going from stock to 460? to 550? I only have around 2 inches maybe less of clearance between the top of the tire and the fender while on stock springs....
IF staying with stock fronts, what would be a balanced rear mono I should try?
If going with 460 in the front.....rear?
550 in front, 360 rear?
Thanks in advance
http://www.duntovmotors.com/frontsuspension.php
Non a/c, sb cars weren't hard on springs.
How many miles are on your car and do you think the springs are original?
I ask for 2 reasons:
They may not need to be replaced... you save $$$.
There are so many posts from people who have ride height problems after replacing springs.
Don't change them if they don't need to be just for cosmetic reasons.
Regards,
Alan
Regards,
Alan
I am actually leaning towards staying with what I have since it looks like its just a bit of rust that can easily be cleaned up. Car has 100k ... springs are in good shape, they were cleaned and painted by one of the previous owners but I have no way of finding out if they are original or were changed at some point just by looking at it.
The reason why I would consider going with new springs is because I plan on going mono in the back... and I've read here numerous times that the rear/front combo should be balanced. It will be easier to get a balanced set up by getting new front and rear.
But here is the catch...going new front might change the ride height which is currently perfect.
