Finished rear valance - Finally
Old Oct 3, 2012 | 03:20 PM
Eric Voigt's Avatar
Eric Voigt
Default Finished rear valance - Finally
I used the replacement rear valance from Corvette Image and their plugs for the rear exhaust openings as well as bonding strips.
I think it came out pretty nice. Couldn't wait to share!
Eric
Old Oct 3, 2012 | 04:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Nice work.
Old Oct 3, 2012 | 04:21 PM
Alan 71's Avatar
Alan 71
Hi Eric,
Yes, nice clean looking rear end!
Regards,
Alan
Old Oct 3, 2012 | 07:01 PM
zwede's Avatar
zwede
Looks like a great fit!
But the bottom of the bumper should be spaced out a bit. That will correct the side part where it is angled up towards the front.
Old Oct 3, 2012 | 07:32 PM
Lupigiato's Avatar
Lupigiato
Eric, how was the fit? Did you have to build on additional glass, or did you have to cut/grind/sand to get that nice snug fit and clean lines? Nice job! I used the valance from Ecklers, I didn't even consider CI and should have looked into it.
Old Oct 3, 2012 | 07:58 PM
Eric Voigt's Avatar
Eric Voigt
Thanks.
The fit was excellent. I bought the Press Molded parts and aside from minor trimming, it was a pefect fit.
The rear of my car had some repairs previously and I had to correct those somewhat to get the panel in correctly. I also replaced the inner bumper brackets as those were bent and when I made the corrections, the originals wouldn't fit anymore.
Once I had the panel in, I bolted the bonding strips to valance and then taped the plugs to the body and maintained the gap/alignment and scribed off the cut line and viola, I had it. Mixed up their boding material and it was done, aside from painting.
Corvette Image supplies to Paragon and, Ecklers....great folks to deal with. Highly reccomend them.
Eric
Old Oct 3, 2012 | 08:09 PM
Lupigiato's Avatar
Lupigiato
Sounds like the easiest part of your project was the panel
Old Oct 3, 2012 | 08:12 PM
WICKEDFRC's Avatar
WICKEDFRC
Looks great!! Very nice and clean work.
Old Oct 3, 2012 | 08:38 PM
3JsVette's Avatar
3JsVette
Very nice. Looks great! Sounds like you were very pleased with the parts you had to work with. It's always a plus to read a good review of a part supplier. Thanks.
Old Oct 3, 2012 | 10:36 PM
straitjacket's Avatar
straitjacket
good hands. nice job
To Finished rear valance - Finally
