picking up a pace car
Not bad for an unrestored 34 year old car.
Ordered a complete dual conversion from Corvette Central, with Magnaflows.
Step one, was removing the old rusted pipes. Wasnt bad, except that the Cat bolts wouldnt budge, which made it impossible for the front pipe to slide through the crossmember. So, I removed the crossmember.
Oh, and one stud on the exhaust manifold broke, rather than let the nut loose.
Step 2) Cleaned up the crossmember and reinstalled. Removed the Cat hangers and heat shields while I was at it. (Anyone want a factory 78 Cat?)
Step 3) Reinstalling the pipes. Driver side was a breeze, but the Pass side pipes seem to be too short, the muffler tips and rear hangers dont match up. Also, the broken (and bent) manifold stud is too tweaked to get the exhaust flange on. I was hoping to get it on and chase the remaining threads..no. Local Vette store didnt have a manifold in stock, so...Rather than fuss with replacing the stud, I got pissed off and ordered a set of McJacks. So much for keeping it stock.
Step 4) Now I wait. The pass side looks too low, and doesnt seem t line up correctly...Oh, and the dual exhaust hanger bracket that goes under the transmission mount doesnt line up with these pipes. Well, it works ok on the driver side. Note also, that the 78-82 dual exhaust hanger bracket attaches to the frame, but there is no existing hole on the driver side. Go figure.
Im hoping once I get the pass side header pipe secured correctly, and adjust the mid-hangers, that the pipes will line up. If not, I guess its off to the muffler shop.
Next I have to rig up a mount for the heat riser and the Stove pipe. Anyone do this already? Save me some effort?
These still need to be adjusted once I get the headers and front pipe back on.....
