Front bumper trim alignment
Old Nov 9, 2012 | 12:09 PM
bellaireroad's Avatar
bellaireroad
Default Front bumper trim alignment
I have noticed on some C3s that the front fender trim chrome does not line up right. Is this an indication of the body panels being out of alignment, or possibly indication of aftermarket replacement?
In the Stingray Guidebook 1969 (Bizzoco) ther is a pick of a front bumper that shows this on page 160 as well, but not commented on as being abnormal.
Old Nov 9, 2012 | 12:36 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bellaireroad
...I have noticed on some C3s that the front fender trim chrome does not line up right. Is this an indication of the body panels being out of alignment...
Usually not.
...or possibly indication of aftermarket replacement?...
Not necessarily. What you see is a bumper guard which needs to be tweaked a bit.
Old Nov 9, 2012 | 03:34 PM
Alan 71's Avatar
Alan 71
Hi ba,
I believe that the grill trim, and the bumper guard, both have a bit of 'wiggle room' during installation.
I believe the gap on the car shown in your picture is probably not typical of factory production.
Regards,
Alan
Old Nov 9, 2012 | 03:35 PM
bellaireroad
Usually not.
Does this mean the bumper guard is not vertical, but leans out toward the fender at the bottom?
Old Nov 9, 2012 | 04:56 PM
Ironcross's Avatar
Ironcross
Default if interested, it might help. as I`m its history
a no hit Vette as it came from the factory 44+ years ago....I`m not sure which is better illustrated of the 2 pictures.....probably the first one
Old Nov 9, 2012 | 05:28 PM
bellaireroad
Looks pretty common .........do they butt together or slide into each other?
Old Jan 14, 2013 | 11:23 PM
MSUGTO's Avatar
MSUGTO
I had actually looked at a '69 this weekend and the bumper itself, the piece that runs the width of the car is off center from the crease in the front bumper by about 3/8", and I looked at each end of the bumper and it does need to be moved to the passenger's side by that same 3/8". Is there that much adjustability in mounting the front bumper?
Old Jan 15, 2013 | 05:47 PM
Alan 71's Avatar
Alan 71
Hi m,
There's actually very little adjustment possible in mounting the bumper itself. That's why you sometimes see a poor bumper fit on cars that have had serious front clip body work. The bumper that will be used, (not just any bumper), must be trial fitted so that the fiberglass can be made to have a good fit with the bumper.
There's actually a bit more adjustment in the bumperettes than the bumper.
Regards,
Alan
To Front bumper trim alignment
