got some of my fiber optics working
now if I could figure out how to change the trim plate lens I'll be in good shape.the AIM dosn't seem to be much help.
Received 2,878 Likes
Hi s,
Both the front and rear fiber optic lenses are held in place with screws..... but, they can only be reached with the shifter console removed.
Regards,
Alan
Regards,
Alan
Doesn’t seem to be enough room to lift the shifter plate out. The heater control and rear fiber optics seem to be holding it in.
I removed the screws, shift **** and vent *****.
that response is typical of a first time Vette owner that is just learning what Vettes are all about
Hi s,
The heater/defroster controller needs to be mounted in just the right way to it's frame and then the frame to the console so the plate can be slid down over it.
The same thing goes for the ashtray frame mounting to the plate.
Have you checked those?
Regards,
Alan
Regards,
Alan
I didn't take the heater controller out,dosn't seem to be much adjustment in the ash tray mounting.I did notice something from your pic though.Let me go outside and take another look,Thanks !!
my heater controller bracket is bent a little.
Love the fiber optic's of the early C3's!
#33
it's back in !! I had a problem with the heater control wheel RH side and one side was up a bit.what made it work is the side that was not going in all the way was to pull up on it while pressing the other side then a shove back in.it was still a little higher up but I was able to get the screw to grab and pull it in.nice and leval everything is working.Now on to the next part of the fiber optics repair.Headlight bulbs with rubber peice over the glass peice.Thanks for everyones help and, encouragement !!
#34
Adam
#36
Great work. I had a 70 model coupe and I always thought the optics were WAY COOL.
