Some Winter Work
Old Nov 18, 2012 | 03:27 AM
Roma's Avatar
Roma
Default Some Winter Work
Hello Together,
I started to exchange and rework some interior things
- Dash pad
- Heater core
- console
- Front carpet (because of water from the old heater core)
- and what ever I find during the disassembly
Here is a pic from where I start :
And where I am currently :
It will take some time as I have not the time I would need to make it within 2 weeks or so
Hope its not to boring for you
Cheers
Frank
Old Nov 18, 2012 | 07:04 AM
pltmgr's Avatar
pltmgr
My interior at this point looks exactly like yours. I'm replacing vent and heater cables. rebuilding clock, rebuilding heater control, replacing after market cassette player (installed in 1985), dealing with a Hurst shifter hitting the console, and attempting to unBubba some wiring issues. I'm trying to be done for a Dec 1 car show, but between waiting on parts and out of town Tday visitors not sure I'll make it. Boring? No. Fascinating!
Old Dec 30, 2012 | 10:08 AM
Roma's Avatar
Roma
The front is empty now
I hope removing the Heater Core will now be easy
Happy New Year
Frank
Old Dec 30, 2012 | 10:13 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Looks good Roma.. and if you get stuck on something there is plenty of help here and on our site for putting that back together. http://willcoxcorvette.com/advanced_...sh+pad&x=0&y=0
One thing I will tell you is that you are only a few bolts form having the column out of the car... Do this before you put the dash pad on the left back in. If the steering column is in you run the risk of breaking the lower U part of the dash pad when going back. Having the column out always makes this an easy job. Another trick when going back is to pull the speedo cable and tach cables loose at the other ends.. and pull them through the dash a bit. This helps you re-assemble easier.
Good luck and Happy New Year.
Old Dec 30, 2012 | 10:20 AM
Roma's Avatar
Roma
Thanks, I assume I need a lot of help
and we will see how the new "Willcox"-carpet fits
Old Dec 30, 2012 | 11:22 AM
dembo's Avatar
dembo
I'm at exactly the same point as you Roma, except the Lh and upper dash pad as I'm changing the heater core. Take care with the plastic parts they are brittle (ducts and housing) and don't silicone everything together like the previous owner did in mine, it makes removing the heater core impossible as everything breakes it's a time consuming job.
Willcox or anyone else, the firewall insulation with black backing does it go in between the heater core housing and firewall or do yoy have to trim it around? I saw on your documents that there are trim lines at the bottom but not for the two top fixations. Doesn't it make the heater box sit angled in relation to the firewall? (see the pic in this thread firewall insulation trimming for ac cars
I don't know if you are changing the insulation as well Roma so I thought this question could interst you as well
Nick
Old Dec 30, 2012 | 11:46 AM
GPGG70's Avatar
GPGG70
Looking Good. Fascinating!
Old Jan 5, 2013 | 12:04 PM
Roma's Avatar
Roma
Can someone tell me how I remove the "Push"-knop from the cluster ?
Frank
Old Jan 5, 2013 | 12:13 PM
9492's Avatar
9492
It is held in place with what I think is called a "push washer". You can gently force it back to remove it. It has little fingers that fit into grooves. These fingers may deform on removal and need to be bent back when you got to reassemble it.
Old Mar 16, 2013 | 02:00 AM
Roma's Avatar
Roma
I have also removed all the trim around the window and hope that someone knows the following:
If you follow the arrow is it clear to let water drain out or closed ?
Old Mar 16, 2013 | 09:39 AM
Alan 71's Avatar
Alan 71
Hi Frank,
I believe it was left open to allow the water to run down the windshield post to the 'gutter extension' on the windshield post weatherstrip.
Regards,
Alan
Old Mar 24, 2013 | 01:44 PM
Roma's Avatar
Roma
Some progress made
Some rustconverter and Paint
Found the screw from engineside and could remove the Heater Core
But no real sign for a leak
Then I had to leave her alone because it was too cold
Old Mar 30, 2013 | 12:25 PM
Roma's Avatar
Roma
And again some things finished
Before :
and after
The difference is not too big, but should be enough for the next 43 years
Ready to install:
and here I have to change the brackets from the old dash to a new one
Tomorrow I hope I can start to install the new heater core ,trim and carpet
In 2 weeks I have to be ready, because there is 60 Years Corvette Aniversity Event I want to attend
Old Apr 6, 2013 | 01:25 PM
Roma's Avatar
Roma
Start to reassemble
Old Apr 6, 2013 | 09:33 PM
ironwills76corvette's Avatar
ironwills76corvette
Looking great, keep up the good work.....
Old Apr 24, 2013 | 02:44 PM
Roma's Avatar
Roma
Still not finished, but drivable
http://forums.corvetteforum.com/c3-g...the-track.html
Old Apr 24, 2013 | 03:18 PM
MrJlr's Avatar
MrJlr
Good Lord - that brings back memories! Very recent memories !
Looking good !
To Some Winter Work
