? Headers with Borgeson box
Old Dec 2, 2012 | 01:00 AM
2box's Avatar
2box
Default ? Headers with Borgeson box
I went through as many threads as I could already and I could not find and specific header that will fit with the Borgeson box. Can someone that has installed this combo in their cars point me in the right direction? I have the box and I am in the process of getting the headers. Any help is greatly appreciated
Old Dec 2, 2012 | 12:41 PM
2box's Avatar
2box
Bump...
Old Dec 2, 2012 | 01:04 PM
qwank's Avatar
qwank
I'll let you know in a few weeks if the Summit brand headers work with it,
Old Dec 2, 2012 | 06:44 PM
2box's Avatar
2box
I can certainly wait a couple of weeks and see the result of your install. Ordering parts at this point and I have plenty prep work to do before I am ready for them. Please let me know how it goes for You and a part # would be nice If they fit OK. Thanks
Old Dec 2, 2012 | 06:49 PM
682XLR8's Avatar
682XLR8
If you're running a small block, the Hooker Comps fit just fine
Old Dec 2, 2012 | 09:07 PM
MalibuVLX's Avatar
MalibuVLX
Big block is an issue. I have a 69 L46 and I put shorty ram horn and had no clearance issue at all.
Old Dec 2, 2012 | 10:15 PM
2box's Avatar
2box
Ouch. A little pricey. Maybe I can go for the non painted ones. Thanks for the reply.
Old Dec 2, 2012 | 10:17 PM
2box's Avatar
2box
Running SBC. I had a chance to get a pair of Hedman 68300 but I was not sure about fit.
Old Dec 2, 2012 | 10:47 PM
qwank's Avatar
qwank
If the Hooker comps fit, the Summit headers should fit since they are a copy of the Hookers.
http://www.summitracing.com/parts/sum-g9003
Old Dec 4, 2012 | 04:49 PM
glackore's Avatar
glackore
I am using Hooker side exhaust. The box slightly touches but that isn't an issue.
Old Dec 5, 2012 | 01:17 AM
2box's Avatar
2box
I read somewhere that this close could transfer extra heat to the box.
Old Dec 5, 2012 | 01:29 AM
Frank_Nesta's Avatar
Frank_Nesta
I am using Patriot Tight Tuck headers with my Borgeson. It took 3 tries before I found them. One source is Jeg PN 737-H8027-1 Coated $273.99. I got mine from J&D Corvettes. There is plenty of clearence between the headers and the steering box.
Last edited by Frank_Nesta; Dec 6, 2012 at 09:34 PM. Reason: corrected which headers I am using as stated in post 24
Old Dec 5, 2012 | 02:31 AM
aussiejohn's Avatar
aussiejohn
Default Sanderson block huggers
Originally Posted by Frank_Nesta
I am using patriot Block Hugger headerswith my Borgeson. It took 3 tries before I found them. One source is Jeg PN 737-H8052-1 Coated $261.99. I got mine from J&D Corvettes. There is plenty of clearence between the headers and the steering box.
I fitted Sanderson block huggers to my '74 350, no problems at all. It has a Borgeson box and Hydroboost. However, I had to remove the factory spark plug shielding on both sides, as the headers really "hug the block." If you can find a header that has the #3 pipe taking a tighter downward turn than the #5 pipe, you should be OK.
A generic SBC header ( not designed for Corvettes ) with equally curved #3 and #5 pipes will usually hit the steering box with the #3 pipe, so you want to avoid those. The other thing you could do is measure the distance between the exhaust flange of the head and the steering box and buy a header that sticks out less than this amount.
Regards from Down Under.
aussiejohn
Old Dec 6, 2012 | 10:20 AM
Jasonb86's Avatar
Jasonb86
I have the "Headman Hedders" on my '70 L46 and they fit without issues. There's plenty of room as the below pictures show.
http://www.summitracing.com/parts/he...model/corvette
Old Dec 6, 2012 | 11:02 AM
Frank_Nesta
Is that a Borgeson streering box? If not the Borgeson box is larger.
Old Dec 6, 2012 | 12:12 PM
Jasonb86's Avatar
Jasonb86
Yes, it's a borgeson box. I fixed the link on my first picture so you can see the whole box.
Old Dec 6, 2012 | 12:48 PM
Frank_Nesta
I did not see the power streering hoses and now realize that the red ring is the fitting plug. Sorry about that.
To ? Headers with Borgeson box
Old Dec 6, 2012 | 12:56 PM
qwank's Avatar
qwank
are those Hedman hedders block huggers or long tube?
Old Dec 6, 2012 | 01:00 PM
Frank_Nesta
[QUOTE=qwank;1582501017]are those Hedman hedders block huggers or long tube?[/QUOTE
Long. See link to Summit above.
Old Dec 6, 2012 | 02:01 PM
mrvette's Avatar
mrvette
Schoenfeld Headers, look up a gig known as 'chassis headers' #151 for SBC, they were 150 bux some years ago....
will clear everything.....rack or Borgeson.....or stock steering,
