Help C3 Overheating!
Old Dec 9, 2012 | 06:06 AM
Cws5214's Avatar
Cws5214
Default Help C3 Overheating!
Guys can you give me some advice on the best thermo fan setup to use on my stock radiator on my C3 350. The motor is new, running around 400hp manual Gear box.
On the open road she runs just under 200 but as soon as I hit traffic she overheats.
I have had the core cleaned and flushed, new water pump and 165 deg thermostat.
Any help would be great.
Cheers,
Paul
Old Dec 9, 2012 | 07:17 AM
dgood's Avatar
dgood
I have heard that a bad radiator cap will cause problems. do you have the air dam under the front bumper? you really need that to get all the air pushed up into the radiator. May have air in you system also. once it is cool, pull the cap and run it for awhile, letting the water flow and you should be able to get all the air out of it.
Another possibility would be a bad fan clutch, if it is not working correctly, that would really effect heat in the stop and go traffic.
Old Dec 9, 2012 | 07:43 AM
JimT's Avatar
JimT
Eliminating air leaks from around the radiator is essential. Also, check your hoses to see if they are weak and collapsing. I use a constant flow type thermostat - this allows any air to escape in your system. You also need to verify that your fan/fan clutch is working properly.
Good luck.
I solved all of my overheating issues by replacing the radiator with a Dewitts unit - a great decision!
Old Dec 9, 2012 | 07:49 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The best setup that actually works is a Dewitt's aluminum radiator and a stock clutch fan. Have you confirmed your gauge accuracy with an IR gun? Is your timing and vacuum advance set up properly? How old is your radiator? I'm not a big fan of trying to clean and flush old radiators.
My cars run 180 in all conditions with stock clutch fans and Dewitt's radiators. Good luck
Old Dec 9, 2012 | 10:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "overheats." What does the Temp Gauge read in traffic?
Old Dec 30, 2012 | 06:15 AM
Cws5214's Avatar
Cws5214
Found out the main problem with the overheating was a damaged lower air dam. Replaced with new one and them now sits around 190 on the open road. Still having overheating issues when stuck in traffic on hot days.
Can you guys recommend the correct Spal fans to run on my stock radiator?
Cheers.
Paul
Old Dec 30, 2012 | 12:36 PM
Mike Ward's Avatar
Mike Ward
Why not find out why it's overheating instead of adding Bubba band-aid fixes? Is the stock shroud in place with all seals? Correct fan and clutch in good working order?
Old Dec 30, 2012 | 07:59 PM
REELAV8R's Avatar
REELAV8R
The air dam and the seals are for highway driving. If I understand the op correctly his problem is at idle while not moving or moving slowly. This would seem to indicate that the problem is lack of air movement generated from the fan.
I would check the fan clutch. Has anything been changed lately that you can attribute to this or has it ran hot since new engine? Can you confirm good water circulation from the pump by looking in the radiator before it gets hot but after the thermostat opens? To do this remove the cap when the engine is cool then start it up. Your 165 thermostat only dictates the minimum temp that the engine will run at. Is the fan shroud still in place?
Old Dec 30, 2012 | 08:19 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Is the gauge lying to you? When the engine is at it's highest, shoot the stat housing with an IR gun. I've seen so many people chasing a problem they don't have
Old Dec 30, 2012 | 08:47 PM
MRANT212's Avatar
MRANT212
As silly as this sounds this actually helped my car ( it's a big block though). If your car is a non-A/C car try an A/C fan as it has an extra blade... I can't make up this stuff..my car runs as cool as ever!! I've since changed my radiator etc but did the blade change quite some time back. A friend of mine told me he used to do this years ago and it helped.
Old Jul 13, 2020 | 03:31 PM
monstr's Avatar
monstr
saw this old thread and wanted to share my experience
My car tended to run hot at idle and slow speeds and somewhat hot at higher speeds (have a 6 blade flex fan with a recently changed copper radiator from PO)
thanks to another forum post I realized ALL of the seals were missing on the fan shroud and I sealed them and its now running a good bit cooler.
That being said it still gets super hot in the cabin and I just saw the old thread about the C3 cabin heat fixes, this forum is full of great info!!
Old Jul 13, 2020 | 10:59 PM
7T1vette's Avatar
7T1vette
You are responding to a thread which has been dead for 8 years. You have good info, but probably should have started another thread.
Old Jul 13, 2020 | 11:02 PM
C3w4sp's Avatar
C3w4sp
Good luck.
this, seals around the rad. essential.
it's simple, air passing through the radiator removes heat from the coolent via the surface area of rad. Hence all the fins. Lack of good seals around the rad allow the forced air from the fan/shroud assy to short circuit going around instead of through. The best new parts available won't get it done if that's the case. That said, mass volume of air forced through the radiator will remove mass amounts of heat from the engine. Think of it, late models kick in the electric fans when your sitting in traffic. Takes more air to exchange the heat.
Old Jul 13, 2020 | 11:07 PM
C3w4sp's Avatar
C3w4sp
Good luck.
I just fell for the old thread thing. Geeeze
Old Jul 14, 2020 | 08:03 PM
7T1vette's Avatar
7T1vette
It happens....(to all of us)
To Help C3 Overheating!
