Compression tester recommendation
Old Dec 15, 2012 | 09:36 PM
mark79,80's Avatar
mark79,80
Default Compression tester recommendation
Would like purchase a compression tester primarily for finding the
compression stroke on number one cylinder to aid when installing
a distributor. May also use for engine compression tests.
Read some reviews of problems with the spark plug adapters
getting stuck in the spark plug hole in some actron models as
well as another brand.
Plan to use in a 1979 and 80 model where the spark plug holes
are a bit difficult to access so don't want to have a problem with
an adapter getting stuck.
For those that have one which model do you recommend?
Old Dec 16, 2012 | 12:22 AM
TimAT's Avatar
TimAT
I've got a Snap-On I've had for years. THe tester itself has a quick coupler on it and the release valve. I've got 4 different hoses with different spark plug threads. The up side to this is the coupler on the hose is the same as my shop air- I can remove the schrader valve from the hose and use it to do leak down tests or change valve springs.
I think Milton makes one too. I've seen a couple others but don't remember who made them.
Old Dec 16, 2012 | 01:06 AM
7T1vette's Avatar
7T1vette
If you are turning the engine over with the starter, you can just pull #1 plug out of the cylinder head and put your thumb near the opening (no closer than 1/4"; you don't want your thumb to get sucked up on an intake stroke .)
You will feel the air being pushed out of the plug hole on the compression stroke. As soon as you feel any air, stop turning the engine over; then manually bring the crank up to the TDC mark. There ya' go....
Old Dec 16, 2012 | 08:40 AM
mark79,80's Avatar
mark79,80
I tried using a finger but could not reach the spark plug threads.
Car has the air pump plumbing. Tried from above and below the
engine.
Old Dec 16, 2012 | 02:11 PM
7T1vette's Avatar
7T1vette
If your finger cannot reach the spark plug threads (in the cylinder head), how could you ever change spark plugs? Your engine should not be running...and it shouldn't be hot. What's the problem?
Old Dec 16, 2012 | 09:05 PM
mark79,80's Avatar
mark79,80
The number one spark plug I can start by turning the end
of the spark plug but cannot quite reach the spark plug hole
with my fingers.
Old Dec 17, 2012 | 02:28 AM
7T1vette's Avatar
7T1vette
Then, how would you ever get a compression test gauge in there?
All I can tell you is: it is easier to stick a finger close to the spark plug hole that it will be to install a compression test gauge.
To Compression tester recommendation
