Steering
Old Dec 16, 2012 | 01:02 PM
mk8035's Avatar
mk8035
Default Steering
Now that i have the engine out of the car. I notice that all the linkage has rubber bushings that are dry looking. What name are theses called and where can i buy replacements?
Old Dec 16, 2012 | 02:06 PM
7T1vette's Avatar
7T1vette
The suspension system has rubber bushings in it. I am unaware of any rubber bushings in the steering system....other than the 'shock' snubbers where the power steering cylinder rod is attached to the frame.
Old Dec 16, 2012 | 02:43 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The Energy Suspension catalog is your friend....
Old Dec 16, 2012 | 02:48 PM
imariver's Avatar
imariver
Th OP may be refering to the rubber dust (?) cups, dirt shields ........
Old Dec 17, 2012 | 02:45 AM
7T1vette's Avatar
7T1vette
If so, those are "dust boots" that are meant to keep the grease IN and the dirt/dust/water OUT of the [metal] steering joints. If you feel the need, you can buy new dust boots; but you have to disassemble the links to get the new dust boots installed. Might as well just replace the joint, if you go to that much trouble.
Oh...if those steering joints were to be greased/lubed at regular intervals, those dust boots might not look so "dry". Just sayin'....
Old Dec 17, 2012 | 06:57 AM
donnie1956's Avatar
donnie1956
You are looking for front end rebuild kit. You may not want to tackle all the parts but the kit has bushings, ball joints and new tie rod ends.
http://www.ebay.com/itm/1963-1982-Co...8a6cdc&vxp=mtr
http://www.youtube.com/watch?NR=1&v=...c&feature=fvwp
Willcox sells this kit.
Old Dec 17, 2012 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Post a pic of what you've found. The idler arm has bushings. Pretty much everything else you might be looking at in the steering linkage is a dust cover.
To Steering
