Radiator Support Panel - Size
Seeking advice in the actual width of the radiator for my 1970 (was 350 - now a 383).
The original radiator is approx 24" wide and the support panel has two steel blanks spot welded in place either side of the radiator. The rhs being approx 7" wide and the lhs being approx 5" wide.
I've just taken delivery of a new 3 core aluminium radiator and it is part number correct according to the supplier however she is 31" wide. This will mean I have to cut out the two blanking panels.
So, what gives with the two panels and smaller size (24") radiator?
Any light shed upon this would be appreciated.
Have a great Christmas, I hope Santa fills your stockings with some nice goodies :-))))
Yes, she's a 4sp (for now) and was giving me high water temp. The new radiator is significantly larger and with three core, should keep the heat-demon at bay.
I'm adept and fabricating so hopefully installing this will not be a big issue.
Thanks again for your advice and info.
Best wishes from DownUnder,
Boris :-)
With a small block and an aluminum radiator cooling shouldn't be a problem, even 'down under'.
It would be good to make sure your fan and fan clutch are operating properly, that the shroud is complete and installed properly, and that all the seals are on the radiator (4 sides), top of the core support, between the lower valance and the core support, and that the small chin spoiler is in place under the valance.
This all insures that the fan is actually pulling the air through the radiator and not around it.
Even with a modified engine (383) the radiator has to have the air flow to cool the engine's coolant.
Regards,
Alan
i just switched a munci to a th400, and used a bb auto trans radiator. i cut out the side plates on the sb rad support and welded lower mounts into place. i mounted a 2003 ford focus fan to the rad with some L shaped brackets. the fan centered perfectly due to the plastic ford mounting tabs. during installation i discovered that the left side upper control arm interfered with the fan, so i had to shift the fan over about 1 1/2 inches to the right by cutting off the right side tabs. fits great now.
I will be mounting twin 12" fans on the front of the new radiator (wiring is already in place).
I'm confident (ok, hopeful) that the existing fan shroud will suffice and given the considerable increase in cooling area, the heat will be kept down to a more manageable level.
Again, thanks for the input - really appreciated.
Boris :-)
