hood problem
Old Dec 29, 2012 | 06:06 PM
rzkas's Avatar
rzkas
Default hood problem
HI? i have a 82 corvette. when i got it, it came with a hood that was over the hood bay. it wasn't the hood of that car but it was a corvette hood. i took my car to the body shop. body shop guy worked on the car and painted the car. when it comes time to put the hood on, he did everything but the hood wouldn't align or fit correctly. there are space side to side and front. what could be the problem. is the hood the wrong hood for the year corvette or could it be something else. check pictures via photo bucket.
http://s1211.beta.photobucket.com/us...30037.jpg.html
Old Dec 29, 2012 | 06:27 PM
vettebuyer6369's Avatar
vettebuyer6369
It's not an '82 hood. It's an aftermarket hood with an L88 scoop on it. Tough to tell if the poor fit is because of the hood or problems with the car.
Old Dec 29, 2012 | 06:42 PM
rzkas's Avatar
rzkas
sorry i did not write that. the body shop added the scoop. the hood was oem. but i like the scoop so i bought the scoop and he added it.
Old Dec 29, 2012 | 06:53 PM
'75's Avatar
'75
A good body shop would have checked all that before paint!
Old Dec 29, 2012 | 07:06 PM
rzkas's Avatar
rzkas
yeah i told him that and he told me when he looked at it he thought it was just an alignment issue but when he went to put in the finish painted hood with all alignment still can't get the hood to be right
Old Dec 30, 2012 | 02:53 AM
vettebuyer6369
The scoop still looks like it was added to a non-'82 hood. '82 hoods have a "bulge" that starts low on the hood... looking at your pictures under the added-on scoop, it doesn't look like an '82 hood to me, scoop or no scoop. I'll have to put some pictures together and look closer.
Still, a professional painter puts the hood on and tests for fit before he starts painting; that's on him. The lower edges of the fit is such a wide gap, I don't know if it's adjustable. Again, not sure if it's the hood or problems with the body. Some better pictures might help.
Old Dec 31, 2012 | 12:14 AM
rzkas's Avatar
rzkas
There are more pictures in photo bucket.
Old Dec 31, 2012 | 02:09 AM
razman's Avatar
razman
why didn't they paint the new scoop?
Old Dec 31, 2012 | 07:06 AM
oldalaskaman's Avatar
oldalaskaman
I like the way the scoop is done , thanks for posting, wondering where you got it? Vettebuyer says it best, that doesnt appear to be a oe hood
Old Dec 31, 2012 | 08:20 PM
crossfire1982's Avatar
crossfire1982
What you have there does not appear to be an 82 hood. You can see the "bulge" that vettebuyer is talking about. Look to see if the under side of the hood has the air induction port for the crossfire air cleaner to mate up.
Old Jan 1, 2013 | 11:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...the hood was oem...
Based on your previous posts, you had a 78 SA hood on your car when you purchased the car. You also had some areas needing body work and hood alignment problems way back then. Which hood is on the car now? The 78?
Old Jan 1, 2013 | 12:07 PM
kdf1986's Avatar
kdf1986
In one of the before painting photos, the hood on the car has a hand written 75 Vette marking on it. Is this the same hood on the car now? In that same photo the passenger side fender looks like it was replaced, or had a lot of work done to it. The gap in this photo is very tight. Yet in the painted car that same area looks like has room. Is this the same hood as the pre painted car.
If the problem is with the fitment of the hood, and this is an original OEM hood, then maybe the alignment problem is with the replacement panels themselves, and not the hood.
kdf
Old Jan 1, 2013 | 04:18 PM
rzkas's Avatar
rzkas
the hood scoop was molded onto the hood and painted black.
Old Jan 1, 2013 | 04:19 PM
rzkas's Avatar
rzkas
i bought the l88 hood scoop on ebay and added it on to a oem corvette hood
Old Jan 1, 2013 | 04:23 PM
rzkas's Avatar
rzkas
Before the top of the hood looks like this hood but it doesn't have induction port. body shop had to cut out the center of the hood and added the l88 scoop.
Old Jan 1, 2013 | 04:28 PM
rzkas's Avatar
rzkas
yes it is the same hood that was on it but now it modified by adding the l88 hood scoop. body shop cut out the center portion of the hood for them to be able to add or mold in the l88 scoop
Old Jan 1, 2013 | 05:08 PM
'75's Avatar
'75
This looks like a 77-79 hood
To hood problem
Old Jan 2, 2013 | 08:52 AM
Easy Mike's Avatar
Easy Mike
...it is the same hood that was on it...
Thought so. You also appear to have the same fit problems you've had from the beginning.
Old Feb 3, 2013 | 04:13 PM
rzkas's Avatar
rzkas
Hi, i will like to am sorry for not posting the pics early. i was away for a while . i am back. here are the pics that you asked me to take. pls go to my photobucket and click on corvette update pics. i did some measure of the hood space with the hood up. between wiper from one end to the other is 44-7/8", behind the carb like carb and distributor is 42-5/8" and by the shroud is 39-1/2" and the front is 37-1/2". the top ends of the hood itself is 45-1/4". you can the measure tape on some pics. thanks
pls help me fix this problem.
for all pics, pls go to photobucket , under library click on corvette update pic for the new pics.
Old Feb 3, 2013 | 05:17 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Passenger door and fender dont line up at all.....
Gonna take a lot of glass to make that hood fit right.
