adding right hand mirror??
Old Jan 1, 2013 | 07:16 AM
oldalaskaman's Avatar
oldalaskaman
if you drill it so its the same as the left side, about 1/2" behind the door skin is a metal strip, with your window rolled up, drill a small hole and then just use a couple of sheet metal screws
I couldnt get the new well nuts to stop the mirrors from wobbling and I didnt want to drill the metal support, so I used metal hollow door anchors, and I used locktite on the screws, nomo wobbles
Old Jan 1, 2013 | 07:17 AM
oldalaskaman
Originally Posted by paul 74
I agree. But with a convertible it is not as crucial. Still I would spring for convex glass.
sound like somethin Mr. Willcox could look into?
Old Jan 1, 2013 | 01:36 PM
MCMLXI's Avatar
MCMLXI
Finalist 2022 C1 of the Year - Unmodified
2020 C1 of the Year Finalist - Unmodified
C1 of Year Finalist (stock) 2019
Originally Posted by 7T1vette
I have a right-hand mirror. It is much better than having NO right-hand mirror. But, I am absolutely SHOCKED that no vendor sells an original-looking early 70's right-side unit with a convex mirror so that it can actually see much!
Totally agree. I discovered this too. I love to use my mirrors, but found a non-convex mirror on the passenger side to be almost useless
Old Jan 1, 2013 | 01:58 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
So who sells good quality mirrors these days. The ones I got from Paragon 8 or so years ago never did stay snug and flog all over the place. Also, I think they went to the larger mirror in 74, so earlier cars cold switch over to those relatively easy.
Old Apr 17, 2013 | 02:56 PM
Spot Rot's Avatar
Spot Rot
I just had a local glass shop trim a convex mirror glass I found to fit my Corvette mirror.
Also, I suggested the idea to a very good Corvette parts supplier. If he chooses to make it, I'll repost.
Old May 4, 2013 | 10:17 AM
Citation X's Avatar
Citation X
OK, I got the RH Mirror from Mid America. It came with the (well nuts) which I have never seen before and find hard to belive that the mirror is not just going to fall off after drilling 3/8" holes in the door. So after the fact I do this search on the subject and find mixed results on their use along with a couple of alternate mounting ideas.
This has me wondering if I should use the well nuts or just take it to a body shop and have them deal with it.
For those who have done this what do you suggest?
Old May 4, 2013 | 11:16 AM
Trae1976's Avatar
Trae1976
I did it over 4 years ago and it hasn't fallen off yet.
Old May 18, 2014 | 02:18 AM
FLYNAVY30's Avatar
FLYNAVY30
I apologize for bringing this old thread back from the dead, but do any of you guys know how far the holes are apart....center to center?
THANKS!!
Old May 18, 2014 | 01:05 PM
7T1vette's Avatar
7T1vette
They are exactly the same distance apart as the holes in the baseplate for whatever mirror you choose....
Old May 18, 2014 | 06:39 PM
FLYNAVY30's Avatar
FLYNAVY30
agreed....I was thinking more along the lines of if you were going to use something other than the stock mirror, and replace the existing mirror(s), then you would want to know how far apart the holes are when looking for suitable replacements so as to verify that it would fit in the factory holes
Old May 18, 2014 | 09:00 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I measured 1 3/4 inches center to center on one of these.
http://www.ecklerscorvette.com/corve...1968-1981.html
Old May 18, 2014 | 09:57 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I put the Rally Sport mirrors on about 35 years ago, After new paint job went back to chrome ones.
On the right hand side i drilled and tapped a 1/8 thick plate and bolted it to the door frame. The plate has the mounting holes for the mirror.
Has held up well.
Old May 18, 2014 | 11:12 PM
  #33
7T1vette's Avatar
7T1vette
Are you really going to drill your door based on some dimension submitted by a post on this Forum? Better wait till you buy the mirror...
Old May 19, 2014 | 02:45 AM
  #34
FLYNAVY30's Avatar
FLYNAVY30
no, not at all....I have no intention of drilling any holes at all....I just wanted to know how far the stock holes are so that I can find a mirror that reuses the stock holes
  #35
FLYNAVY30's Avatar
FLYNAVY30
Old May 19, 2014 | 07:23 AM
  #36
FLYNAVY30's Avatar
FLYNAVY30
figures every mirror on the market uses posts that are 2" on center....
