c3 battery location
http://www.ncrs.org/forums/forumdisp...cal-Discussion
) most likely moved it to a more accessible location.
All manual trans, small block, no air 68's used the same 19" aluminum radiator, with the separate expansion tank, as 63-67 small block Corvettes. 68 small blocks with air conditioning and/or automatic and big block 68's used copper radiators with attached tanks.
If your car is a 327, manual trans, without AC (and I'm sure you don't have air, as a battery would never fit in the area under the evaporator box of a factory AC car), it should have an expansion tank . Any other 68 will have a radiator with attached tanks.
I've never heard of a 68, with an under hood battery. I know of 2 very early 68's, one is one of the first 80 cars, and the other has a VIN near yours. Both of these cars have the battery in the rear compartment.
When it comes to 68's, anything is possible, but I'd want to have more info before I'd claim that the factory mounted the battery, under the hood!
I too think it's pretty unlikely this configuration came from St.Louis.
I'd be interested in seeing pictures of the battery box fiberglass with out the holes, and also the battery cables that were used.
Regards,
Alan
My thinking is that a mid-year owner found the 68+ location very inconvenient and moved the battery to where he was used to it being.
I can certainly understand someone making that change since having the battery behind the driver's seat is pretty inconvenient.
Thanks for the pictures.
I felt that if this was something that was done at St.Louis early in 68 production there would be some knowledge of it as thoroughly as 68 cars have been scrutinized.
Can we see the REST of your new, old, car now?
Regards,
Alan
Are you implying that perhaps some 'comparison testing' was done with other makes and models on the streets of Detroit?
That kind of activity would have be illegal, wouldn't it!?!?
Regards,
Alan
Have you read Burton's biography of Duntov? There is a hint of some of the uses for Corvette corporate cars in the Detroit area.
