Build sheet for a 1971
Old Jan 6, 2013 | 10:04 AM
71VetCan's Avatar
71VetCan
1st Gear
Default Build sheet for a 1971
Does anyone know the best way to get the build sheet for a pre-Bowling Green 1971 ? Through General Motors ?
Old Jan 6, 2013 | 10:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 71VetCan
...Does anyone know the best way to get the build sheet for a pre-Bowling Green 1971 ? Through General Motors?...
You can't; the records do not exist. If you do not have an original, you're pretty much SOL like most of us.
Have you tried contacting previous owners to determine whether any of them might have some of the old records for your car?
Old Jan 6, 2013 | 11:16 AM
MRANT212's Avatar
MRANT212
It's a bummer not being able to find a way to get it. Been trying to figure how to get one for years...the answer SOL is accurate.
Old Jan 6, 2013 | 12:31 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
You can always have one of the on-line document services make "a" build sheet (as opposed to "the" build sheet) up for you...just tell them what you want it to say. Just don't expect the next caretaker to be impressed and pay you extra for it.
I looked a long time for the right car...and paid dearly for it. I saw many nice cars, but passed on all of them because they did not have the original documentation.
Old Jan 6, 2013 | 01:01 PM
7T1vette's Avatar
7T1vette
Those 'document reproduction' services do not have access to the original information about your car. They merely create a similar-looking document from the information about the car that YOU supply to them.
You can do the same thing yourself, with any word processing program on your computer.
Old Jan 6, 2013 | 08:01 PM
Clay master's Avatar
Clay master
Default Pre bowling green
Not sure what u mean when u say pre bowling green. Can u explain
Also when I bought my 71. I was given 2 build sheets. Is the other one worth anything? Thanks. Clay
Old Jan 6, 2013 | 08:26 PM
7T1vette's Avatar
7T1vette
Corvettes were built/assembled in St. Louis until the plant in Bowling Green, KY opened in 1981.
The only 'build sheets' of value for a 1971 are the one(s) that came with the car from the assembly plant. This could have been placed on top of the fuel tank, behind the speedo/tach housings, or in the dash area. A new car also had an MSRP sheet stuck to the driver's window, and the original sheet can be used for valid documentation, also.
There is no "original" build information on St. Louis-built cars retained by General Motors. It was probably thrown away over 30 years ago, when Corvette production was moved to the Bowling Green plant.
Old Jan 7, 2013 | 08:58 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Clay master
...when I bought my 71. I was given 2 build sheets. Is the other one worth anything?...
Are the two sheets you were given the same? One should be a copy of the other. Post pics of what you have.
Here ya go. Good reading here. Well worth the cost of a copy.
Old Jan 11, 2021 | 06:15 PM
Allen Frisch's Avatar
Allen Frisch
1st Gear
Go to corvettemuseum.org and register. It will cost you $50.
Old Jan 11, 2021 | 09:10 PM
62corvette's Avatar
62corvette
And at that point you have not a bit more information, and you are out $50.
Old Jan 11, 2021 | 09:12 PM
ed427vette's Avatar
ed427vette
8 year old thread
To Build sheet for a 1971
